29641 Discussions
Optimized Compile for Fast Execution
samsampath
I am trying to create an executable of a short test program that carries out an exponential arithmetic over a very large number of loops. The purpose is to test the speed of execution of the Compaq compiler. Initial results using optimized settings seem to indicate that this ompiler created executable is about 1.6 times slower than the Lahey LF95 compiler. However, I have seen an article that implies that the Compaq compiler created executable should improve in speed if I used the following setings:
df %1 /fast/opt:5/link/stack:64000000
The question is - How to use these settings in the Visual Fortran window
Replies would be greatly appreciated
Ignore the /link/stack switches - they don't affect performance. I gather you were looking at the Polyhedron site.
Project..Settings..Fortran..General. Set optimization level to "Maximum Optimizations" - that's /opt:5. Then go to the Optimization section of the settings and check the box "Generate most optimal code" (/fast).
Steve
