Output problem of parameterized derived type
Blane_J_
Hi, there's  a problem of outputting parameterized derived type. Assume this:
program main
    implicit none
    type :: test(l)
        integer, len :: l = 99
        character(l) :: s
    end type test
    type(test(10)) :: str = test(10)("1234567890")
    write(*,*) str%s
end program main
This generates a runtime error of memory conflict when accessing libifcoremdd.dll, so where is the mistake ? Appreciate any reply.
Xiaoping_D_Intel
Can you provide the compiler version and the compilation command line? I tried  both 16.0 update 3 and the latest 17.0. None of them produced the error.
Xiaoping Duan
Intel Customer Support
Blane_J_
I'm using Intel(R) Visual Fortran Compiler XE 15.0.6.285 [IA-32] and the command line:
Compile:
/nologo /debug:full /Od /warn:interfaces /module:"Debug\\" /object:"Debug\\" /Fd"Debug\vc140.pdb" /traceback /check:bounds /check:stack /libs:dll /threads /dbglibs /c
Link:
 /OUT:"Debug\Project.exe" /INCREMENTAL:NO /NOLOGO /MANIFEST /MANIFESTFILE:"Debug\Project.exe.intermediate.manifest" /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /DEBUG /PDB:"D:\Project\Project\Debug\Project.pdb" /SUBSYSTEM:CONSOLE /STACK:10000000,10000000 /IMPLIB:"D:\Project\Project\Debug\Project.lib"
Xiaoping_D_Intel
I can reproduce the error using 15.0 compiler. It should be a compiler bug which has already been fixed in the newer 16.0 and 17.0 version. So please upgrade your compiler to the newer version.
Xiaoping Duan
Blane_J_
Xiaoping Duan
That's OK, thanks a lot.
