Overiding Slash Editing
cloneboy
I am having a problem reading certain data from a file, and was womdering if someone here had any idea how to solve the problem.
THe data I need is in an external file. I read the line in as a character string, and then read the data from that string. The string looks like:
0 1 CEN/4 -5.000000E-03 -1.407595E+06 -1.407595E+06 -7.747229E+05 -45.0000 -6.328721E+05 -2.182318E+06 1.944713E+06
and the data requred is the second value, and the last value. The problem is the slash in CEN/4, which tells FORTRAN to jump to the next line, and so the second value is not read. I have tried using the T command to move the pointer, to no avail. Is there any way of overriding the slash editing to enable me to read the last value?
Many thanks
David
TimP
Surely there's a way. If you're simply trying to skip over it, doesn't a format specifying that field as a character string work?
The slash doesn't mean anything in the input, but if you are using list-directed input (* format), then it will consider the slash to be a separator. If you are using an explicit format, then the slash is just another character. If all the fields are in the same columns, you should be able to use T to position within the record. What code are you using to read it?
greldak
You could always split your string into 2 parts - the bit before and the bit after the slash and then just read from the substring - or even just have the second substring contain everything after the last space in the trimmed string.
larsm
Just a note to add to Steve's reply about a slash being a separator for list-directed format. It's true, of course, but it also stops the processing that list. This is what the standard states:
Although a slash encountered in an input record is referred to as a separator, it actually causes termination of list-directed and namelist input statements; it does not actually separate two values.
If you have used list-directed input I guess this is the reason why you cannot read the last value, David.
LarsM
