27675 Discussions
Overloaded operator for derived type undefined when imported from a wrapper module
Milan_Curcic
The following code does not compile with Intel Fortran v16, v17, on x86-64 Linux:
module mymod
implicit none
type :: mytype
  private
  integer :: a
  contains
  procedure,private :: eq
  generic :: operator(==) => eq
endtype mytype
interface mytype
  module procedure :: constructor
endinterface mytype
contains
type(mytype) function constructor(a)
  integer,intent(in),optional :: a
  if(present(a))then
    constructor % a = a
  else
    constructor % a = 0
  endif
endfunction constructor
logical function eq(m0,m1)
  class(mytype),intent(in) :: m0
  class(mytype),intent(in) :: m1
  eq = m0 % a == m1 % a
endfunction eq
endmodule mymod
module wrapper_module
use mymod,only:mytype
endmodule wrapper_module
program test
use wrapper_module
implicit none
write(*,*)mytype() == mytype(0)
endprogram test
The compiler does not seem to resolve the overloaded == operator for mytype:
$ ifort test.f90
test.f90(44): error #6355: This binary operation is invalid for this data type.
compilation aborted for test.f90 (code 1)
If the main program accesses mytype directly from mymod, the program compiles and executes as expected.
If the main program accesses mytype from wrapper_module, and wrapper module accesses mytype via "use mymod", the program compiles and executes as expected.
If the main program accesses mytype from wrapper_module, and wrapper module accesses mytype via "use mymod,only:mytype" (the example code above), the compilation fails with the above message. I think this is unexpected behavior.
The code compiles and executes as expected when compiled with gfortran 5.x
milan
Steven_L_Intel1
Thanks - this is an issue we're already working on. Issue ID is DPD200374263.
milan_c_1
Just a follow-up, the issue remains as of Intel Fortran 19.0.1.144 Build 20181018.
Cheers,
milan
Izaak_Beekman
New Contributor II
This still seems to be present even in the latest compiler. Any updates on the Intel side?
Juergen_R_R
Valued Contributor I
For me this works with ifort v19.0.3 and v19.0.4 as well as with the beta version of 19.1.0. So it seems that this bug has been fixed.
milan_c_1
Thanks Juergen, it looks like it's time for an update. :)
