[PGO] no .dyn files
bucaioni__thomas
The INTEL_PROF_DYN_PREFIX variable is set to /tmp, but no .dyn file appear in the directory. The flags I use are:
-prof-gen=threadsafe -mtune=haswell -extend-source -static -echo
and my program exits with the stop command, which shouldn't be considered an error. Did I miss something?
Steve_Lionel
My guess is that the STOP bypasses the normal image exit code. Try removing the STOP and see what it does.
bucaioni__thomas
The sacct command returns ExitCode 0:0 for both jobs, with and without commenting the stop instruction. The instruction immediately following stop is end.
When the INTEL_PROF_DYN_PREFIX variable is not defined, there is no .dyn file neither in the run directory. The run directory is not the same as the compilation directory, it's not allowed by the administrator
Steve_Lionel
It's been a long time since I've played with PGO. I'll leave this to others with more experience. You might want to try some simple examples all in the same directory, and then incrementally make environment changes to closer to your real one to see what changes.
Barbara_P_Intel
According to the Developer Guide
NOTE The value specified in this environment variable must not contain < > : " / \ | ? * characters. The default naming scheme is used if an invalid prefix is specified.
Maybe the prof-dir compiler option will help. Details at the above link.
bucaioni__thomas
So the .dyn file should be in the directory of execution?
bucaioni__thomas
With a simple hello.f, there is a .dyn file. Thank you
bucaioni__thomas
So, the compile and run directories must be the same... Many thanks
The execution time has improved only 2" compared to the -Ofast option. The first compilation doesn't need the flag -Ofast, only the second one. Am I right?
Maybe it takes to remove the .o files before the second compilation?
Barbara_P_Intel
I'm sorry that I wasn't clearer.   The environment variable INTEL_PROF_DYN_PREFIX must not contain < > : " / \ | ? * characters.  /tmp is not valid.
The compiler option -prof-dir  (-Qprof-dir on WIndows) specifies a directory for profiling information output files (*.dyn and *.dpi). The specified directory must already exist.
bucaioni__thomas
It worked, thank you very much for your help
Barbara_P_Intel
That's good news!  You're welcome!
