Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
26744 Discussions
PREFETCH Directive and MM_PREFETCH Intrinsic
Sina_M_
Hi every one.
For performance issues I want to make Intel Fortran compiler transfer an array range from main memory to L1 or L2 cache. In order to do that I tried !dec$ prefetch directive and mm_prefetch intrinsic function with several different parameters while the Prefetch Insertion option was enabled in the Visual Studio's Optimization tab. But unfortunately neither of them affects the cpu time. Besides I tried those features on both Intel and AMD CPUs but there was no difference between the results.
Can anyone help me in this topic?
