PSXE 2018 crash
dajum
I got this from the compiler:
sf_interfaces.f
010101_14291
catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
010101_14291
ifort: error #10298: problem during post processing of parallel object compilation
compilation aborted for C:\sf61\proces\nnfc.f (code 1)
DOT.f
ifort: command line remark #10148: option '/Qopenmp-report2' not supported
010101_14291
compilation aborted for C:\sf61\proces\DOT.f (code 1)
I tried to figure out how/where to submit a Software Problem Report searching the website, but failed.  Can you provide a link?  Or is this the right place?  Maybe the message could be improved.
Dave
Steve_Lionel
In the forum's first page, click "Tech Support".  This takes you to https://software.intel.com/en-us/support/  Then click Online Service Center. On the next page, click Online Service Center (I don't care for this extra step.) That takes you to https://supporttickets.intel.com/?lang=en-US where you can submit a ticket (Request Support). You'll have to sign in again, probably.  I recommend choosing the option to "Search for a product or service by name" and type in "Fortran".
dajum
It appears the website won't work correctly using Firefox.  I switched to IE and got farther.  But I didn't see your exact text of "Search for a product or service by name".  There was a search,  when I entered Fortran it came back with nothing found (wow you rate high in Intel search engines).  But did give a related seach for "Intel Fortran for Windows"(maybe I'm doing from memory).  But clicking that again returned nothing found.  I can get here https://www-ssl.intel.com/content/www/us/en/support/software.html  ; But the compilers seem to be missing.  Seems incredibly hard to navigate the intel website, so your help is appreciated.  I'd send a picture to help you help me, but my first screen shot doesn't meet the intel requirements on size for picture attachments.
dajum
I managed to get a hold of Intel on the phone where they created a case number for me and promised an automated email that would contain a link to my case in 5-7 minutes.  It has been over an hour.  Calling back the phone number he gave me to ask about the case # results in a menu option that only includes hardware questions, which says hold the line and speak with a representative at the end.  Repeats twice and hangs up on me.  All I want to do is submit my Software Problem Report as requested by the compiler error message.  Why is this so hard to do?
Steve_Lionel
dajum
I can't get to that screen.  Maybe there is a problem with my account that I can't fix myself.  I've attached a .pdf that shows what I see.
dajum
Note that from the page https://supporttickets.intel.com/?lang=en-US it has a big blue section that says if you need more help "Contact Support" with a link.  That link is for the page you are on, nice infinite loop.  At this point I need some help with my account as it seems that it has problems.  But how do I get help with that?
Devorah_H_Intel
dajum,
I am sorry you are having trouble with login. I will contact you via private message and help you with the account issue. I will also delete the attachment as it contains private info.
Steve_Lionel
Yeah, that self-referential link is unfortunate.
