29640 Discussions
Parameterized Derived Data Type and OpenMP
Baxter
I am having a problem using parameterized derived data types with openMP.
I would like to have a derived data type (mytype), that contains both an integer (idx) and an array (a). The array (a) has a dimension (n) that is not known at compiler time, so I parameterize it.
Then I want an array of mytypes (x) of length (m).
This all works great without OpenMP. However, when I try to parallelize it, I get racing conditions that produce terminal errors. For example "forrtl: severe (157): Program Exception - access violation"
Debugging suggests that the problem is that when one thread creates a new instance of x, in assigning the dimension (n) it overwrites the dimension (n) on all other thread's version of x. So if thread 2 assigns n=2, and then thread 1 assigns n=1, when thread 2 goes to access x(:)%a(2) I get an error because thread 1 has overwritten the dimension of (n).
See minimal working example below.
It appears that mytype's parameter (n) is shared across threads. My questions are:
- Is there a way to explicitly make mytype's parameter (n) private?
- Am I trying to violate a standard of which I am unaware here?
- Is there a better way to do this that maintains the array (x) of derived times (mytype) containing an array (a) of unknown size at compiler time?
!! Module
module Program_SomeMath
    implicit none
        type mytype(n)
        integer, len                        :: n
        integer                             :: idx
        real*8, dimension(n)                :: a
    end type mytype
    contains
    subroutine SomeMath(i)
        implicit none
        integer, intent(in)                         :: i
        type(mytype(i)), dimension(i)               :: x
        integer                                     :: j, k
        do j=1,i
            do k=1,i
                x(k)%idx=k
                x(k)%a(j)=dble(j)**2+k
            end do
        end do
        do j=1,i
         write(*,"(A,4I,30f12.0)") 'a=', i,j, size(x(j)%a), x%n,  x(j)%a
        end do
    end subroutine SomeMath
end module Program_SomeMath
!! Main Program
program ParameterizedDerviedDataAndOpenMP
    use Program_SomeMath
    implicit none
    integer                                                 :: i
    integer, parameter                                      :: z=10
    !$OMP PARALLEL DEFAULT(PRIVATE)
    !$OMP DO
    do i=z,1,-1
        call SomeMath(i)
    end do
    !$OMP END DO
    !$OMP END PARALLEL
end program ParameterizedDerviedDataAndOpenMP
Labels (2)
Baxter
Update. The below example appears to have solved this problem by making (a) an allocatable array within the derived data type.
!! Module
    implicit none
        type mytype
        integer                             :: idx
        real*8, dimension(:), allocatable   :: a
    end type mytype
    contains
        implicit none
        type(mytype),dimension(:), allocatable               :: x
        integer                                     :: j, k
        allocate(x(i))
        do j=1,i
            allocate(x(j)%a(i))
        end do
        do j=1,i
            do k=1,i
                x(k)%idx=k
            end do
        end do
        do j=1,i
         write(*,"(A,4I,30f12.0)") 'a=', i,j, size(x), size(x(j)%a),  x(j)%a
        end do
        deallocate(x)
!! Main Program
    implicit none
    ! Variables
    integer                                                 :: i
    !Body
    !$OMP DO
    do i=z,1,-1
        call SomeMath(i)
    end do
    !$OMP END DO
    !$OMP END PARALLEL
