Fyi for readers - an incident has been submitted at the OSC for the following:
type :: t(ell) integer, len :: ell character(len=1) :: s(ell) end type integer, parameter :: N = 2 type(t(ell=:)), allocatable :: foo foo = t(ell=N)( s=transfer(source=repeat("x",ncopies=N), mold=[ character(len=1) :: ], size=N) ) end
Compiler output:
xxx>ifort /c /standard-semantics /warn:all /stand p.f90 Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 18.0.0.124 Build 20170811 Copyright (C) 1985-2017 Intel Corporation. All rights reserved. p.f90(9): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Softwa re Problem Report. Note: File and line given may not be explicit cause of this error. compilation aborted for p.f90 (code 1) xxx>
Call me a Luddite but I have yet to touch a PDT even with a long stick, and I think I will ignore them for some time yet along with Visual Studio 2017 and venomous snakes.
andrew_4619 wrote:
.. I have yet to touch a PDT ..
@Andrew,
See this thread and try out code in Quote #30,
https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/746406
PDTs can be very powerful and useful.
Unless more users try them out, the bugs will remain "hidden" in the compiler body like a virus for a long time.
Here's another case that has been turned in at the OSC:
type :: t(ell) integer, len :: ell end type type :: u type(t(ell=:)), allocatable :: x end type type(t(ell=:)), allocatable :: foo type(u) :: bar allocate( t(ell=1) :: foo ) bar = u( x=foo ) end
xxx>ifort /c /standard-semantics /warn:all /stand p.f90 Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 18.0.0.124 Build 20170811 Copyright (C) 1985-2017 Intel Corporation. All rights reserved. p.f90(14): catastrophic error: **Internal compiler error: internal abort** Pleas e report this error along with the circumstances in which it occurred in a Softw are Problem Report. Note: File and line given may not be explicit cause of this error. compilation aborted for p.f90 (code 1) xxx>
If you are a Luddite, Andrew, then I'm a pre-Luddite. I'm still using IVF 11.0.075, which I find completely satisfactory.
