29487 Discussions
Parameterized derived type kind declaration order
DataScientist
Valued Contributor I
This Fortran code snippet compiles with gfortran, but not with Intel because the Intel Fortran compiler wants the kind declarations to be the first in the type block. Which behavior is standard-conforming?
program pdt_kind_order
    type :: pdt_type(ikind, rkind)
        integer         :: np
        integer , kind  :: ikind
        integer , kind  :: rkind
    end type pdt_type
end
Here are the error messages:
pdt_kind_order.f90(2): error #8723: This type parameter name has not been defined.   [IKIND]
---------------------^        pdt_kind_order.f90(2): error #8723: This type parameter name has not been defined.   [RKIND]
----------------------------^        compilation aborted for pdt_kind_order.f90 (code 1)
Steve_Lionel
gfortran has an extension - the standard (F2018 R726) says that type-param-def-stmts must appear first, then private-or-sequence, and then components. If gfortran doesn't complain about this when you ask for standards checking, it's a bug.
Steve_Lionel
