29487 Discussions
Parameterized derived types with PASS
Simon_Geard
I'm trying to use parameterized derived types and have run into a problem which I have distilled into the following code:
module t_mod
    implicit none
    type T(k)
        integer, kind   :: k = 4
        integer(kind=k) :: d
    contains
        procedure, public, pass(x) :: check_v
    end type T
    contains
    logical function check_v(k, x)
        integer  :: k
        class(T) :: x
        check_v = (k == x%d)
    end function check_v
end module t_mod
I get the following compilation error:
error #8262: For a type-bound procedure that has the PASS binding attribute, the first dummy argument must have the same declared type as the type being defined.
How should I declare k in order for this to compile ?
This is a bug that will be fixed in version 16. It's not fixed in the current beta but should be in the first beta update.
Simon_Geard
Thanks. I was using the current v16 beta so I'll wait for the update.
