When I try to install fortran compiler it gives the following error message (IA32 for my i586-suse-linux). Please help me to successfully install the compiler .
ERROR: unable to find command "g++" !
It appears that one of the missing commands is the 'g++' command.
Some Linux distributions do not include 'g++' as a part of the 'gcc' installation.
Please locate and install the proper 'g++' package for your system and restart
the installation process for this Intel software product
Please add the location to the above commands to your PATH and re-run the script.
Please press Enter to continue...
So pop in your SuSE install DVD, open up YaST/software installation, and install g++ along with the displayed dependencies. Then start the ifort installation again, checking yes if it has the bad manners to ask if you want an unsupported installation.
I will try that. Thanks for your reply.
