Pls Help-FORTRAN call C++ function
wisperless
I have Visual studio 2005 and IVF9.1 compiler installed on 64 bit machine (windows XP for 64 bit OS). I am trying to call a C++ function from FORTAN, but it failed. Here is what I did for the testing.
1). Start a new IVF project (console application) from VS2005 named mixed_programing
Code:
 program mixed_programing
implicit none
INTERFACE
SUBROUTINE TEST(I, J)
!DEC$ ATTRIBUTES REFERENCE :: I,J
INTEGER I,J
END SUBROUTINE
END INTERFACE
integer I,J
CALL TEST(I, J)
print *, 'Hello World'
 end program mixed_programing
2). Add a newwin 32 console projectto this mixed_programing FORTRAN project.
Code:
// C code.cpp : Defines the entry point for the console application.
#include "stdafx.h"
int _tmain(int argc, TCHAR* argv[])
return 0;
extern "C" void TEST(int *i,int*j)
*i=1;
*j=2;
Then compile, it gives me the following error,
1>------ Build started: Project: mixed_programing, Configuration: Debug Win32 ------
1>Compiling with Intel Fortran 9.1 C:Program Files (x86)IntelCompilerFortran9.1IA32...
1>mixed_programing.f90
1>Linking...
1>mixed_programing.obj : error LNK2019: unresolved external symbol _TEST referenced in function _MAIN__
1>Debug/mixed_programing.exe : fatal error LNK1120: 1 unresolved externals
I have been working on solving this issue for couple of days, but still can not make it work. Please help. Thank you!!
Rachel
The C project should be a Static Library project, not a console application, because the latter creates its own executable. Remove the _tmain main program from the C code. Make the C library be a dependent project of the Fortran project (right ckick on the Fortran project and select Dependencies. Make sure that the C and Fortran library settings are compatible (in Fortran this is set under Libraries and in C++ under Code Generation.)
You don't need the !DEC$ ATTRIBUTES line, though it doesn't hurt.
wisperless
Steve,
Thank you. It works. :))
A quick question about MS visual studio compiler. Does IVF 9.1 compiler inegrate with any other microsoft visual studio compiler which can run on a 64-bit machine except VS 2005? I am so frustrated with using VS 2005.
Thank you.
Rachel.
No, VS2005 is the only VS which supports development of x64 applications. What are you frustrated about? Have you installed the new Service Pack 1 for VS2005? It fixes some problems that affect Fortran users.
wisperless
Steve,
Thank you for your response. I met a lot of problems when I tried to port a project mixed with FORTAN6.1 and VC++6.0 to IVF9.1 and Visual Studio 2005 on a 64-bits machine(OS: windows XP). One of my problems is how to code a project that a C++ will call a function in FORTRAN, and the FORTAN function will call another C++ function?
For example:
int main()
int i,j;
C_CALL_FORTRAN(&i.&j);
FORTRAN:
subroutine C_CALL_FORTRAN(i,j)
integer i,j
i=1
j=1
CALL FORTRAN_CALL_C(i,j)
C++ function
void FORTRAN_CALL_C(*i,*j)
Thank you again for your help!
Rachel.
This is no different than any other mixed Fortran-C application. Since the main program is in C, you have a C executable application (console, Win32, whatever) and a Fortran static library project which is made a dependent of the C project. I suggest that you install VS2005 SP1 to fix a bug related to dependent projects.
You also need to take the following steps to get thingsto link properly:
  • In the Fortran project, Properties, Libraries, set "Disable default library search rules" to No.
  • Make sure that the "Use run-time library" setting in the Fortran project is compatible with what is set under "Code Generation" in the C project
  • In Tools..Options..Projects..VC++ Directories, add the Intel Fortran EM64TLIB folder to the list of library folders.
