29649 Discussions
Poblems debugging IFX program with VS2019 version 16.11.51
Gabriel_Toro
I am using IFX 2025.2 with Visual Studio 2019 v. 16.11.51. In the watch window of the debugger, I can't see variables with derived types that were defined in modules using
TYPE(**bleep**), PUBLIC, SAVE ::  MYVARIABLE(MYSIZE),
where MYSIZE is defined as a PARAMETER in another module. All modules involved are properly USE'd in the subroutine in question.
I would appreciate any suggestions.
Thank you,
Gabriel
andrew_4619
watch <module-name>::<var-name> that usually works in such cases.
