29619 Discussions
Point array(type) error in OpenMP fortran
britz0907
I used to pointer as a firstprivate variable in omp parallel do due to compatibility between intel system(IFORT) and IBM system(XLF).
However, intel system generates  below errors.(IBM-xlf can run without error, but value is incorrect.)
*** glibc detected *** ./RGFM.x: double free or corruption (out): 0x00007fffe7ec27a0 ***
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x7eb96)[0x7f4bec8a0b96]
./R.x[0x482299]
./R.x[0x43d03b]
/opt/intel/composer_xe_2013.5.192/compiler/lib/intel64/libiomp5.so(__kmp_invoke_microtask+0x93)[0x7f4bed382293]
======= Memory map: ========
My code is
program
TYPE ATOM_DATA
sequence
INTEGER :: name
REAL :: coord(3)
END TYPE
TYPE (ATOM_DATA), POINTER :: atom_block(:,:)
integer,pointer :: block_natom(:)
integer:: nthreads,block_num,nsmp
nthreads = 4
block_num = 100
nsmp = 100
C$OMP PARALLEL do private(..... ,
C$OMP& ismp,  atom_block) firstprivate(block_natom)
     DO ismp = 1, nsmp
     allocate(block_natom(0:block_num+1))
CALL setup_blockham(block_natom,atom_block) < - error from this subroutine
end
subroutine setup_blockham(block_natom,atom_block)
INTEGER :: block_natom(0:block_num+1)
TYPE (ATOM_DATA) :: atom_block(0:block_num+1,block_num)
real ,pointer :: Vp(:)
CALL onsite_ham(atom_block(block_num,:)) < - error from this subroutine
end
subroutine onsite_ham(block_num)
TYPE (ATOM_DATA) :: atom_block(max_block_natom)
DO ii=1,n/2
W = Vp(atom_block(ii)%name) < - I've checked error here due to trash value of garbage passing and stop
ENDDO
My ifort is composer_xe_2013.5.192
britz0907
Note (about above codes)
Due to security of my job, I wrote pesudo code and my loop-indexs(my mistakes)are omiited(but correct).
jimdempseyatthecove
atom_block is declared as 2D array, but allocated as 1D array (I assume this is a typeo).
Your pseudo code has ATOM_DATA typed in PROGAM and not in a module. The subroutines are not USE-ing the same module defining the ATOM_TYPE type. Add a module to define type ATOM_TYPE.
Also, either place the subroutines manipulating ATOM_DATA types in the CONTAINS section of the module defining ATOM_DATA types .OR. add the INTERFACE blocks to the external subroutines (manipulating ATOM_DATA types) into the data declaration section of the module defining ATOM_DATA types (then USE that module in the subroutines manipulating ATOM_DATA types.
This will assure you do not have issues of passing: a) different ATOM_DATA types, b) differing ranks of ATOM_DATA type arrays.
Jim Dempsey
britz0907
Thanks Jim
Could I have another question to you?
As I mentioned, I declare pointers for dynamical array in do-loop.
But I checked same values with openmp (if no error) except for master thread.
For example, do i = 1,16 & number of threads=4
master threads deal with i = 1,2,3,4
other thread 1  deal with i = 5,6,7,8
other thread 2  deal with i = 9,10,11,12
other thread 3  deal with i = 13,14,15,16
values of other thread 1 = other thread 2 = other thread 3
This is situation very unexpceted.  WHY?
And Do I have one more question?
If I have a pointer values as private on omp parallel region, a pointer values is really not effected by other threads?
Such as below
complex pointer:: kk(:,:)
c$omp parallel do private(kk)
allocate(kk(i,i)) <- i = variable during do procedure
above kk is not really affected other threads?
I think this is a point. But I don't know really WHY same values with openmp (if no error) except for master thread.
jimdempseyatthecove
Can you post a short example? Insert comments in code with your questions.
Jim Dempsey
