Pointer rank remapping ICE
styc
Compile the attached code with ifort 13.1.0.146. The compiler crashes no matter which definition of x is used.
Heinz_B_Intel
I will escalate the problem to compiler  engineering; thanks very much for the small test case !
Heinz
Heinz_B_Intel
I filed the issue as case DPD200241543; I will let you know here, when a fix will be available
Heinz_B_Intel
This is fixed now  in the 15.0 compiler
