29145 Discussions
Poor openmp scaling with ifort but not gfortran
hweintraub
I’ve been seeing some strange openmp scaling behavior that I’m not sure how to explain.
I have a simple test program that scales nicely when compiled with gfortran but poorly when compiled with ifort.
My test program is the following:
module parserMod
  use function_parser, only : fparser_array
  implicit none
  type(fparser_array), save :: parser
  !$omp threadprivate(parser)
end module parserMod
subroutine parallelMarbles(marbles, numThreads)
  use parserMod, only : parser
  use iso_fortran_env, only: wp => real64
  use iso_fortran_env, only : output_unit
  real(wp), dimension(6,200000), intent(inout) :: marbles
  integer, intent(in)                     :: numThreads
  integer :: indx
  character(len=1), dimension(3), parameter :: parserVars = ['x', 'y', 'z']
  ! All threads initialize the parser
  !$omp parallel num_threads(numThreads)
  call parser%parse(parserVars,parserVars)
  if (parser%error()) then
    call parser%print_errors(output_unit)
    stop 99
  endif
  !$omp end parallel
  !$omp parallel do default(none) &
  !$omp private(indx) &
  !$omp shared(marbles) &
  !$omp num_threads(numThreads)
  do indx = 1, size(marbles(1, :))
      marbles(1,indx) = 1
      call doWork(marbles(:,indx))
  end do
  !$omp end parallel do
end subroutine parallelMarbles
subroutine doWork(marble)
  use omp_lib, only : omp_get_thread_num
  implicit none
  real(wp), dimension(6), intent(inout) :: marble
  integer :: indx
  do indx = 1, 200
    marble(2) = mod(indx, 6 + omp_get_thread_num())*marble(1)
    marble(3) = mod(indx, 5 + omp_get_thread_num())*marble(1)
    marble(4) = mod(indx, 4 + omp_get_thread_num())*marble(1)
    call parser%evaluate(marble(1:3), marble(4:6))
    marble(1) = sum(marble(2:))
  end do
end subroutine doWork
program testOMP
  ! real(wp), allocatable, dimension(:,:)    :: marbles
  real(wp), dimension(6,200000)    :: marbles
  integer                                  :: numThreads
  real                                     :: singleTime, threadTime
  integer :: startTime, endTime, countRate, countMax
  character(len=25)   :: varString
  ! allocate(marbles(6,200000))
  do numThreads = 1, 4, 3
    write(*,*) 'Calling parallel marbles with ', numThreads, ' threads.'
    call system_clock(startTime, countRate, countMax)
    call parallelMarbles(marbles, numThreads)
    call system_clock(endTime)
    threadTime = (dble(endTime) - dble(startTime))/dble(countRate)
    write (varString, '(F25.6)') threadTime
    write (*, '(A)') ' Loop time = ' // trim(adjustl(varString)) // ' seconds.'
    if (numThreads .eq. 1) then
      singleTime = threadTime
    endif
    write (varString, '(F25.6)') singleTime / threadTime
     write (*, '(A)') ' Speedup = ' // trim(adjustl(varString)) // 'x.'
    write(*,*) '------------------------------------------------------'
  end do
end program testOMP
 My code uses the fortran_function_parser module from:
https://github.com/jacobwilliams/fortran_function_parser
I've attached the source files for the test program along with the fortran function parser module for convenience.
Any insight into what might be going wrong in ifort and how I might improve the performance with ifort would be greatly appreciated.
Labels (2)
