Portability of Executable files
Nan_Deng
We developed some applications and compiled with Visual Fortran v11 to be used on multiple workstations. However, I found the compiled executables are no completely portable - I must copy one library file named libiomp5md.dll to the searchable path to make the executable to run. Did I miss something in downloading the compiler or I have used wrong flags in compilation? Any help is greatly appreciated.
anthonyrichards
New Contributor III
I believe that he first 'd' in 'libiomp5md.dll indicates that you have dependence on a debug library. So you have to recompile all your files making sure that you have selected release configuration.
No, that would be "mdd".
By default, the OpenMP library is linked as a DLL library. You can add /openmp-link:static to specify a static library, but this option may go away in a future release.
The alternative is to install the compiler redistributables on the target system.
Jugoslav_Dujic
Valued Contributor II
Out of curiosity, what does that final "d" in libiomp5md stands for? What about libifcoremd? I find it terribly confusing with Debug libraries.
This is a Microsoft convention that matches the Visual C++ switches used to select libraries.
md = /MD = DLL
mt = /MT = Multithreaded static library
However, debug DLL libraries don't usually follow this. For example, msvcrt is the regular DLL whereas msvcrtd is the debug DLL. I guess if it ends specifically in "md" then it's a normal DLL. If the ending is something else followed by d, then it's probably a debug dll.
