29486 Discussions
Possible Regression in IO routines from IFORT 2021.3.0 to 2021.4.0
Stephen_Sutcliffe
New Contributor III
I have just rebuilt a project using the latest version of the IFORT compiler and the resulting program crashed with an Access Violation Exception. The same code did not flag any exceptions and appeared to work as intended when compiled with 2021.3.0 or any earlier versions.  The culprit seems to be either backspace or the ifport function GETPOSI8.
I've created a reproducer which demonstrates this in attached zip file containing source code, data and solution files.
program FilePosBug
implicit none
! Local variables
character(132) :: Filename = 'Main_File.txt'
character(132) :: buf
logical :: TOF,TOF1,TOF2
integer :: linecount
integer :: ier
integer :: io
! Function
logical :: utl_TopOfFile
! Initialise
io = 8
linecount = 0
! open a text file (must have over 107 lines)
Open(unit=io,file=FileName,status='old',iostat=ier)
if(ier.eq.0) then
! Scan file
  do
    read(io,'(a)',iostat=ier) buf
    if(ier.eq.-1) exit
    linecount = linecount + 1
    backspace(io,iostat=ier)
    TOF1 = utl_TopOfFile(io)
    TOF2 = utl_TopOfFile(io)
    TOF = TOF1.and.TOF2
  ! Reread
    if(.not.TOF) then
    endif
    write(*,'(a,i5,2x,a)') 'Line count ', linecount, buf
  enddo
  close(unit=io)
else
  write(*,'(a)') 'Error: Cannot open file '//trim(filename)
endif
end program
logical function utl_TopOfFile(iunit)
! Return true if file access pointer is at the top of the file
use ifport
implicit none
! Arguments
integer,intent(in) :: iunit
! Local Variables
integer(8) :: ipos
! Initialise
utl_TopOfFile = .false.
ipos = GetPosI8(iunit)
if(ipos.eq.0) then
utl_TopOfFile = .true.
endif
return
end function
The idea of the code is to identify if the line read is the first line in the file. It is not that elegant but has done the job for a number of years until now. In the reproducer example the same function is called repeatedly (once for each line in the text file) and program eventually crashes after107 calls.
The text file can contain any data but consist of at least 107 lines.
I have only looked at x64 configuration and confirm that this access violation is occurring when compiled with IFORT 2021.4.0.
Hopefully someone at Intel can have a look at this.
Steve
Stephen_Sutcliffe
New Contributor III
Thanks Barbara, I'll stick with 2021.3.0 for now.
Barbara_P_Intel
Thanks for such a nice reproducer! I printed ier after each backspace; it always returns 0. That's good. I also printed ipos after the call to GetPosI8(). The values of ipos are different between the 2021.4.0 compiler and 2021.3.0. Looks like a regression.
I filed a bug on your behalf, CMPLRLIBS-33593. I'll keep you posted on its progress to a fix.
Stephen_Sutcliffe
New Contributor III
Barbara_P_Intel
This issue is fixed in ifort version 2021.6.0. It was released recently as part of Intel oneAPI 2022.2.
Please give it a try!
