Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Possible bug in ifort: using polymorphic types
I get different results depending if I comment specific lines out or not (even as those are not accessed at runtime). The bug does not appear using gfortran.
program main
  implicit none
  type :: parent
    integer              :: i1
    integer, allocatable :: i2
  end type
  type, extends(parent) :: child
    integer              :: i3
    integer, allocatable :: i4
  end type
  type :: parent_alc
    class(parent), allocatable :: p
  end type
  type(parent_alc) :: p_alc
  if (.false.) then
    block
      ! type(child) :: e            ! comment this line in/out for different results
    end block
  else
    block
      type(child)      :: c
      c%i1 = 1
      c%i2 = 1
      c%i3 = 1
      c%i4 = 1
      ! method 1: broken in ifort
      ! p_alc%p = c
      ! method 2: broken in ifort
      ! allocate (p_alc%p, source=c)
      ! workaround
      allocate (child :: p_alc%p)
      select type (x => p_alc%p)
        type is (child)
          x%i1 = c%i1
          x%i2 = c%i2
          x%i3 = c%i3
          x%i4 = c%i4
      end select
      c%i1 = 0
      c%i2 = 0
      c%i3 = 0
      c%i4 = 0
    end block
  end if
    type is (child)
      print *, 'p_alc%p%i1..4', x%i1, x%i2, x%i3, x%i4
  end select
end program
Running the program using method 1,2 and commenting in/out the highlighted line 23 yields different results with ifort and the same in gfortran.
Line commented out
$ ifort main.f90 && ./a.out
p_alc%p%i1..4           1           1           1           1
$ gfortran main.f90 && ./a.out
Line not commented out
p_alc%p%i1..4           1           0           1           0
Program versions
$ ifort --version
ifort (IFORT) 19.0.1.144 20181018
Copyright (C) 1985-2018 Intel Corporation.  All rights reserved.
$ gfortran --version
GNU Fortran (Arch Linux 9.3.0-1) 9.3.0
Copyright (C) 2019 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
The "workaround" code actually works under ifort/gfortran with and without line 23.
Highlighted
Valued Contributor III
An option you may want to
An option you may want to consider if possible is to update your compiler version.  Version 19.1 appears not to face the issue:
C:\Temp>type p.f90
program main
   implicit none
   type :: parent
      integer              :: i1
   end type
      integer              :: i3
   end type
   type :: parent_alc
   end type
   if (.false.) then
      block
      end block
   else
      block
         type(child)      :: c
         c%i1 = 1
         c%i2 = 1
         c%i3 = 1
         c%i4 = 1
         p_alc%p = c
      end block
   end if
      type is (child)
   end select
end program
C:\Temp>ifort /standard-semantics /warn:all /stand:f18 p.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.1.0.166 Build 20191121
Copyright (C) 1985-2019 Intel Corporation.  All rights reserved.
p.f90(23): remark #7712: This variable has not been used.
Microsoft (R) Incremental Linker Version 14.24.28316.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:p.exe
-subsystem:console
p.obj
C:\Temp>p.exe
C:\Temp>
C:\Temp>type p.f90
program main
   implicit none
   type :: parent
      integer              :: i1
   end type
      integer              :: i3
   end type
   type :: parent_alc
   end type
   if (.false.) then
      block
      end block
   else
      block
         type(child)      :: c
         c%i1 = 1
         c%i2 = 1
         c%i3 = 1
         c%i4 = 1
      end block
   end if
      type is (child)
   end select
end program
-out:p.exe
-subsystem:console
p.obj
C:\Temp>p.exe
C:\Temp>
Thanks for the fast reply!
I will try it out with the newer version. Hope it works and not some internal thing caused by the underlying OS (linux/windows).
Highlighted
Black Belt
The code in #2 is missing the
The code in #2 is missing the trailing assignment statements necessary to see the bug - 19.1 is still problematic.
I have encountered issues previously with over-enthusiastic deallocation of block local variables (or components of block local variables) with the current compiler.  I suspect that is going on here - move the block local variables up to the enclosing scope and the symptoms disappear.
Highlighted
Bummer!  Support request at Intel OSC appears to be in order: https://supporttickets.intel.com/servicecenter?lang=en-US ;
