Possible bug in passing assumed-rank arguments
Peil__Oleg
Originally, the issue was posted as a problem with Intel MPI: https://software.intel.com/en-us/forums/intel-clusters-and-hpc-technology/topic/852075 However, it has turned out to be related to the Fortran compiler itself. An unexpected segfault occurs when one tries to pass a 2D array subsection of a multi-dimensional array to a subroutine defined with an assumed rank dummy argument `type(*), dimension(..)` [defined in Fortran 2015 standard]. These types of arguments are heavily used in `mpi_f08` interface of the MPI 3.x standard. The following minimal example should demonstrate this behavior. The program runs and prints the correct values but then crashes with a segfault when it tries to leave subroutine `test_assumed_rank_arg()`. The program is compiled from two files, `test_assumed_rank.f90` and `c_fun.c`, as follows:
icc -c c_fun.c
ifort -o test_assumed_rank test_assumed_rank.f90 c_fun.o
Source files:
module test_assumed_rank_mod
   implicit none
   integer, parameter :: dp = kind(1.0d0)
   type :: Container
      real(kind=dp), allocatable :: arr(:, :, :)
   end type
   interface
      subroutine c_fun(arr, n) bind(C, name='c_fun')
         use iso_c_binding, only: c_ptr, c_int
         type(c_ptr), value :: arr
         integer(c_int), value :: n
      end subroutine
   end interface
contains
   subroutine fun(arr, n)
      use iso_c_binding, only: c_ptr, c_int, c_loc
      !> arr will be treated as an array of real(dp)
      type(*), intent(inout) :: arr(..)
      integer, intent(in) :: n
      type(c_ptr) :: p_arr
      integer(c_int) :: c_n
      p_arr = c_loc(arr)
      c_n = n
      call c_fun(p_arr, c_n)
   end subroutine fun
   subroutine test_assumed_rank_arg()
      type(Container) :: cont
      allocate(cont % arr(1, 1, 1))
      cont % arr(1, 1, 1) = 42.0_dp
      print *, " before `c_fun`: ", cont % arr(1, 1, 1)
!---> works      call fun(cont % arr(:, 1, 1), 1)
      call fun(cont % arr(:, :, 1), 1)
      print *, " after `c_fun`: ", cont % arr(1, 1, 1)
   end subroutine test_assumed_rank_arg
end module test_assumed_rank_mod
program test_assumed_rank
   use test_assumed_rank_mod
   call test_assumed_rank_arg()
end program
The C-function is defined as follows (in c_fun.c):
#include <stdio.h>
void c_fun(void *p, int n) {
   // Assume that `p` points to an array of double
   double *p_arr = (double *)p;
   printf("n = %d\n", n);
   printf("`p` contains: %lf\n", *p_arr);
I reiterate relevant details from the original post:
  • The subroutine must be in a module
  • The array must be at least 3-dimensional, allocatable, and be contained in a derived type object
  • The subsection must be at least 2-dimensional. As noted in the comment in the source above, 1D subsection does not cause any issue.
Compiler/library versions:
Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.1.1.217 Build 20200306
OS: CentOS Linux release 7.6.1810 (Core)
Kernel: 3.10.0-957.10.1.el7.x86_64
FortranFan
Thanks for sharing.
  • Assume you've reported this to Intel Support (https://supporttickets.intel.com/servicecenter?lang=en-US) and they've opened an incident for this issue?
  • By the way, it's Fortran 2018 standard, not 2015.
  • And technically, you need TARGET attribute with your assumed-rank and assumed-type dummy argument 'arr' in your procedure 'fun' for the code to conform i.e., C_LOC procedure requires its parameter 'X" to have either the TARGET or POINTER attribute.
  • If you change the dummy argument in 'fun' to be of type REAL(dp) i.e., not have it as assumed-type, your trouble case also works.  This might be of help to Intel Fortran team diagnose and resolve the issue.
Peil__Oleg
Thanks for response.
FortranFan wrote:
I have made an attempt to do that but all the formatting seems to have gone south (and, unfortunately, there is no preview of what is to be sent). Anyway, I've left the links to the forum threads. This should help to get the source listings.
Yes, you are right. The issue has probably more to do with TS 29113.
Noted. I essentially just copied the subroutine interface as defined in `mpi_f08`, as the issue first started to pester me in the context of an MPI application.
Steve_Lionel
Black Belt Retired Employee
You don't need the C routine to see this problem - remove it and the call to c_fun (though the C routine at least lets you see that the array was passed correctly.)
The error occurs when test_assumed_rank tries to deallocate local allocatable variable cont. I'm guessing that the code that set up the call to fun somehow corrupted the data that would later be passed to for_deallocate_all_nocheck.
Peil__Oleg
Thanks for this comment. Then, the issue seems to be unrelated to TS29113 and CFI, as I suspected at first.
jimdempseyatthecove
Black Belt
passes the address of the array descriptor and not that which is the address of the first array element.
Jim Dempsey
Steve_Lionel
Jim Dempsey
Yes, as it has to. But the compiler knows to look in the descriptor for the base address - and it does.
Steve_Lionel
The problem is related to TS29113, as that's where TYPE(*) and DIMENSION(..) come from. But it is unrelated to C descriptors.
