Code below compiles and functions as expected with Intel 2013, 15, and 16. Intel 17 gives ICE. Other compilers seem to handle it as well. We have a workaround in the "big" code, but would be curious to know if this is valid code or not.
ifort (IFORT) 17.0.1 20161005
Copyright (C) 1985-2016 Intel Corporation. All rights reserved.
Thanks!
Eric
module prob
type ddt1
real :: f ! function
real :: d ! the derivatives of f
end type ddt1
interface assignment(=)
module procedure ddt1_assign_rd
end interface
contains
function fun_rd(v1) result(f1)
real, intent(in) :: v1
type(ddt1) :: f1
f1%f = v1
f1%d = 0.0
end function fun_rd
subroutine ddt1_assign_rd(r, d)
real, intent(out) :: r
type(ddt1), intent(in) :: d
r = d%f
end subroutine ddt1_assign_rd
end module
program problem
use prob
implicit none
real :: var1
var1 = 1.0
var1 = fun_rd(var1)
print *, var1
end program problem
The code looks conformant. I note the internal error occurs where var1 appears as the argument to fun_rd. The internal error should not occur whether the code is conformant or not. Thank you for reporting this and for the convenient reproducer. I reported this to our Developers.
(Internal tracking id: DPD200417568)
