Printing graphics
Brooks_Van_Horn
If I have a window DC (sDC) and a printer DC (pDC), why can't I just draw into pDC the way I would a sDC? Or if I have a DIB, how di I print it? I would really like to know of any experience yoiu've had with this.
Brooks Van Horn
Paul_Curtis
Valued Contributor I
Here is a routine which prints a bitmap to an already-initialized printer device context (hdc_printer).  The bitmap in this case is passed as a resourceId already defined via the resource editer, or as a handle to a bitmap generated or acquired by some other means.  This routine is part of a larger module which INCLUDEs IFWIN and IFWINTY.
FUNCTION print_bitmap (hdc_printer, resourceId, hBmap, &
                       xpos, ypos, mult, origin) RESULT (res)
	IMPLICIT NONE
	INTEGER(HANDLE), INTENT(IN)	:: hdc_printer, hBmap
	INTEGER, INTENT(IN)	        :: resourceId, xpos, ypos, origin
	REAL,    INTENT(IN)	        :: mult
	INTEGER(HANDLE)		        :: hdc_screen, hbitmap, hlib
	INTEGER				        :: rval, res
	INTEGER				        :: swide, shigh, pwide, phigh, bwide, bhigh
	TYPE(T_RECT)		        :: rect
    TYPE(T_BITMAPINFO)          :: bmi
	!	NOTE - use of these functions requires that DIBSECTN.LIB be included
	!	in the link build and that DIBSECTN.DLL be present in the runtime path
	!INTERFACE
	!	INTEGER(4) FUNCTION DSLoadDIBSectionFromBMPFile (fname, hbitmap, hpalette)
	!	!DEC$ ATTRIBUTES DLLIMPORT, STDCALL,ALIAS:'_DSLoadDIBSectionFromBMPFile@12':: DSLoadDIBSectionFromBMPFi
    !   !DEC$ ATTRIBUTES REFERENCE :: fname
    !       CHARACTER*(*) fname
	!		INTEGER hbitmap
	!		INTEGER hpalette
	!	END FUNCTION DSLoadDIBSectionFromBMPFile
	!END INTERFACE
	INTERFACE
		INTEGER(4) FUNCTION DSDrawDIBSectionOnDC (hdc, hbitmap, lprect)
		!DEC$ ATTRIBUTES DLLIMPORT, STDCALL,ALIAS:'_DSDrawDIBSectionOnDC@12':: DSDrawDIBSectionOnDC
			INTEGER hdc, hbitmap, lprect
		END FUNCTION DSDrawDIBSectionOnDC
	END INTERFACE
	!	scaling factors, screen to printer
	hdc_screen = GetDC (NULL)
	swide = GetDeviceCaps (hdc_screen,  LOGPIXELSX)
	shigh = GetDeviceCaps (hdc_screen,  LOGPIXELSY)
	pwide = GetDeviceCaps (hdc_printer, LOGPIXELSX)
	phigh = GetDeviceCaps (hdc_printer, LOGPIXELSY)
    !   load bitmap from supplied resource identifier
    IF (hBmap == 0) THEN
	    res = -1	! cannot load library
	    hlib = LoadLibrary ('DIBSECTN.DLL'C)
	    IF (hlib == 0) GO TO 20
        res = -2	! cannot load bitmap
	    hbitmap = LoadImageID (ghInstance, resourceId, IMAGE_BITMAP,  &
	                           0, 0, LR_CREATEDIBSECTION)
	    IF (hbitmap == 0) THEN
	        rval = FreeLibrary (hlib)
	        RETURN
	    END IF
	    res = -3	! bitmap has null extent
	    CALL GetBitmapSize (hbitmap, hdc_screen, bwide, bhigh)
		IF (bwide /= 0 .AND. bhigh /= 0) THEN
			bwide = IFIX(mult*FLOAT(bwide)*FLOAT(pwide)/FLOAT(swide))
			bhigh = IFIX(mult*FLOAT(bhigh)*FLOAT(phigh)/FLOAT(shigh))
			!	displace mapping rectangle wrt local origin
			SELECT CASE (origin)
			CASE (top_left)
				rect%left   = xpos
				rect%right  = xpos + bwide
				rect%top    = ypos
				rect%bottom = ypos + bhigh
			CASE (mid_left)
				rect%left   = xpos
				rect%top    = ypos - bhigh/2
				rect%bottom = rect%top + bhigh
			CASE (bot_left)
				rect%left   = xpos
				rect%bottom = ypos
			CASE (top_right)
				rect%left   = xpos - bwide
				rect%right  = xpos
				rect%top    = ypos
			CASE (mid_right)
				rect%right  = xpos
			CASE (bot_right)
				rect%right  = xpos
				rect%bottom = ypos
			END SELECT
			res = -4	! cannot transfer DIB section to printer
			IF (DSDrawDIBSectionOnDC (hdc_printer, hbitmap, LOC(rect)))	&
				res = rect%bottom - rect%top + 1
		    rval = DeleteObject (hbitmap)
	    !   use supplied handle to existing bitmap
	    ELSE
	        hbitmap = hBmap
            bmi%bmiHeader%biBitCount = 0
            bmi%bmiHeader%biSize     = SIZEOF(bmi%bmiHeader)
            rval = GetDIBits (hdc_printer, hbitmap, 0, 0, 0, LOC(bmi), DIB_RGB_COLORS)
            IF (rval == 0) THEN
                banner(1) = 'GetDIBits error'
                CALL API_Error (hbitmap)
            END IF
            bwide = bmi%bmiHeader%biWidth
            bhigh = bmi%bmiHeader%biHeight
			!bwide = IFIX(mult*FLOAT(bwide)*FLOAT(pwide)/FLOAT(swide))
			!bhigh = IFIX(mult*FLOAT(bhigh)*FLOAT(phigh)/FLOAT(shigh))
            rval = SetDIBitsToDevice (hdc_printer,  & ! device context
                                      0, 0,         & ! device x,y ULC
                                      bwide, bhigh, & ! source dimensions
				                      0, 0,         & ! source x,y LLC
				                      0, bhigh,     & ! scan line start, count
				                      LOC(hbitmap), & ! DIB bits array
				                      bmi,          & ! bitmapinfo structure
                                      DIB_RGB_COLORS) ! RGB or palette index flag
	    END IF
	END IF
20	rval = ReleaseDC (NULL, hdc_screen)
END FUNCTION print_bitmap
Paul_Curtis
	IMPLICIT NONE
	!INTERFACE
	!		INTEGER hbitmap
	!		INTEGER hpalette
	!END INTERFACE
	INTERFACE
	END INTERFACE
	        RETURN
	    END IF
			CASE (top_left)
				rect%left   = xpos
				rect%top    = ypos
			CASE (mid_left)
				rect%left   = xpos
			CASE (bot_left)
				rect%left   = xpos
				rect%bottom = ypos
			CASE (top_right)
				rect%right  = xpos
				rect%top    = ypos
			CASE (mid_right)
				rect%right  = xpos
			CASE (bot_right)
				rect%right  = xpos
				rect%bottom = ypos
			END SELECT
	    ELSE
	        hbitmap = hBmap
            IF (rval == 0) THEN
            END IF
	    END IF
	END IF
Brooks_Van_Horn
Thanks Paul, but where do I acquire this DIBSECTN.LIB and DIBSECTN.DLL. They are not on my Win 10 x64 system.
Thanks, Brooka
Brooks_Van_Horn
Also, what happens if there is no resource id. My problem is that I want to capture a part of my screen and print it.I can create a dib with the bm inside itt but then what. I have the code as follows:
     iret = StartDoc(hdcPrn, INFO)
     iret = StartPage(hdcPrn)
    ...... what do i do here????
     iret = EndPage(hDCPrn)
     iret = EndDoc(hDCprn)
     bret = DeleteDC(hDCprn)
     bret = ReleaseDC(ghWndMain, phDC)
andrew_4619
reading Paul's code, if you have the bitmap structures populated and a dc for the print device then it seems to me that you just need to call "SetDIBitsToDevice"
dboggs
If you were using Quickwin this would all be very easily accomplished in just a few (less than 10?) lines of code. That is, if you can settle for capturing the screen to a bmp file (which I usually convert to a tif or gif file) for later printing. But I don't think you are, so I will reserve the specifics for those who are interested.
Also: are you looking for publication quality in your graphics, or is it OK if the "printed" image as only the very crude resolution of a monitor's screen?
An interesting and undocumented note: The "screen" in a Quickwin window is actually a virtual screen, as it can be made any size at all and needn't fit within a window or even the entire monitor. In this way the resolution of the captured graphics can be made extremely high. I usually make my captured graphics 600 dpi, but there is no problem making them 1200 or 2400 dpi or really anything you want. And I don't understand why, but the publishers I work with prefer high-resolution bitmap graphics files instead of scalable vector files.
Brooks_Van_Horn
