29649 Discussions
Private variable are not correct when using OpenMP
siyuliben
I am using OpenMP to run a program.
I use 'MODULE' to define varibales. Within the omp do loop, subroutines are called and the variables are used in the subroutine. But when the private variables that are used in subroutine are not correct as what it was outside the subroutine.
I created a simple example. It is attached and shown below.
Integers 'icount' and 'abc' are not the same in the MAIN program and the SUBROUTINE called 'Mysubroutine'. However, the shared value 'sumcount' is correct.
module parm
integer :: icount
integer :: sumcount
integer :: abc
end module parm
program run
use parm
use omp_lib
implicit none
character(len=5) :: Name
sumcount=0
!$omp parallel
!$omp& shared ( sumcount )
!$omp& private ( icount, Name, abc )
!$omp do
do icount = 1, 2
write(*,*) icount
write(Name,'(I5.5)') icount
write(*,*) Name
abc = 123
sumcount = sumcount +1
call Mysubroutine(Name)
end do
!$omp end do
!$omp end parallel
end program run
subroutine Mysubroutine(Name)
use parm
use omp_lib
write (*,*) Name
write (*,*) icount
write (*,*) sumcount
write (*,*) abc
end subroutine Mysubroutine
jimdempseyatthecove
In your program run, prior/subsequent to the parallel region with private(abc), the abc (should it be) referenced would be the abc of the module parm. This would also be the same abc of the module parm.
In your program run, the parallel region contains private(abc), thus a new instance of abc (same type) is created for each of the threads run within the parallel region (master thread can potential use the abc of the module parm).
Therefor you have an inconsistency with your stated use of private(abc) and your query for "How should I make both 'subroutine Mysubroutine' and 'program run' recognize 'abc' as the same variable?"
So I need to ask: Do you want a) all threads to share the same abc? Or, b) each thread to have unique abc (without passing abc as a dummy argument)?
if AND ONLY if b), then attribute abc in the module parm as THREADPRIVATE.
Jim Dempsey
jimdempseyatthecove
Some issues with your program
1) While abc is private in the omp parallel region in program run (same type as in the module parm but local to the parallel region), it is not the abc as used by subroutine Mysubroutine (which uses the module abc).
2) sumconunt, while shared is not atomically incremented. Thus, you may encounter a race condition between different threads perform: Read, Modify (increment), Write.
3) icount is a loop control variable which may or may not be registerized and thus you may be (likely are) reading a stale value.
Jim Dempsey
siyuliben
Thank you Jim,
Thank you very much.
jimdempseyatthecove
Jim Dempsey
siyuliben
Thank you Jim,
I need each thread to have unique abc,
So I shouldn't set abc as private in program 'run', the module should be:
module parm
  integer :: icount
  integer :: sumcount
  integer :: abc
  !$OMP threadprivate(abc)
end module parm
jimdempseyatthecove
Yes on placement of threadprivate
Also use
    !$omp atomic update
    sumcount = sumcount + 1
to assure sumcount is updated correctly.
Jim Dempsey
