Probelm with bessel_jn(m1, m2, x)
steven_j_
I have a module with a number of subroutines. Some of the subroutines use calls to the two-argument bessel function bessel_jn(n, x). When I add a new subroutine to the module that uses the three-argument bessel function bessel_jn(m1, m2, x), the compiler tells me that this function is not recognized and is therefore assumed to be external. Why is it refusing to recognize the three-argument bessel function?
Thanks!
andrew_4619
My guess is the the type/kind of the parameters and result variable are not correct
mecej4
Black Belt
I think that the Bessel functions J and Y were added to the list of intrinsic functions in Fortran 2008; they were not present in Fortran 2003. Which version of the compiler did you use? Please show enough of the source code to help us see what went wrong. In particular, show the function references, and show the declarations of the arguments and the function, if any.
Steve_Lionel
Black Belt Retired Employee
Please also show the complete and exact text of ALL the error messages. The one you mention is usually preceded by another which is much more detailed.
steven_j_
Below is the relevant text of the problematic subroutine I was adding to the module. When I attempt to compile it (Intel Parallel Studio XE 2018 in Visual Studio 2015), I get the following error messages:
Error error #6404: This name does not have a type, and must have an explicit type.   [BESSEL_JN]
Warning warning #7532: The number of arguments is incompatible with intrinsic procedure, assume 'external'.   [BESSEL_JN]
When I replace the three-argument bessel_jn below with the two-argument bessel_jn(n, xq), the module compiles with no problem and runs correctly. However, I want to modify this subroutine to evaluate moments for two different orders of the Bessel function - that is why I want to use the three argument bessel_jn. One call to bessel_jn(m1, m2, gamm*rq) should be significantly faster than two calls to bessel_jn(m1, gamm*rq), bessel_jn(m2, gamm*rq).
steven j
subroutine CCBesselChebMoments(n, a, b, gamm, NM, J, ErrFlag)
! Evaluates the Bessel-Chebyshev moments between a and b of orders 0:NM
! as functions of gamma:
!   J(k) = integral from r = a to r = b of Tk(x) * Jn(gamm*r)
! where x = 2*(r - a)/(b - a) - 1, 0 <= k <= NM.
    use MKL_DFT_TYPE  !For FFT
    use MKL_DFTI      !For FFT
    implicit none
    integer, intent(in) :: n       !Bessel function order
    real*8, intent(in) :: a, b     !Endpoints of region of integration
    real*8, intent(in) :: gamm     !Value of the moment variable
    integer, intent(in) :: NM      !Maximum order of the moments
    real*8, dimension(:), allocatable, intent(out) :: J  !The moments
    integer, intent(out) :: ErrFlag
!-----Local variables.
    integer status, NQ, k
    type(DFTI_DESCRIPTOR), POINTER :: FFT_Handle
    real*8, dimension(:), allocatable :: aux, w
    real*8 h2, xq, rq, JB(n+1)
!-----Initialize.
    ErrFlag = 0
    if (allocated(J)) deallocate (J)
    allocate (J(0:NM))
    J = 0.d0
    if (b .le. a) return
    h2 = (b - a)/2.d0
!-----Set number of Clenshaw-Curtis quadrature points.
!-----Note: The choice below for NQ assumes Jn can be represented by a polynomial of order ceiling(gamma*h)
    NQ = NM + ceiling(gamm*2.d0*h2)
    NQ = NQ + mod(NQ, 2)  !NQ must be an even number
!-----Quadrature.
    call CCWts(-1.d0, 1.d0, NQ, w, ErrFlag)  !Evaluate Clenshaw-Curtis quadrature weights
    if (ErrFlag .ne. 0) then
        return
    end if
    allocate (aux(0:2*NQ+2))  !Storage for array to be transformed
    aux = 0.d0
    do k = 0, NQ
        xq = cos(pi*k/dble(NQ))
        rq = a + h2*(1.d0 + xq)
        xq = gamm*rq
        JB = bessel_jn(0, n, xq)
        aux(k) = w(NQ-k)*JB(n+1)
    end do
mecej4
Black Belt
I added "RETURN" and "END" to the code that you gave, and I find that the 2016U8 and 2018U3 compilers compiled the subroutine code without any messages.
steven_j_
Yes, I have only observed this compiler problem when this subroutine is included in a module and the module has other subroutines that use the two-argument bessel_jn. For example, if you copy the subroutine I posted (and add the return and end subroutine statements as you did) into a module, and compile the module, it compiles without a problem. But if you then paste another copy of this subroutine into the module, (with a different subroutine name) and change the three-argement bessel_jn to a two-argument bessel_jn in this new subroutine, the resulting module will not compile and will return the error messages I posted in my previous message. It appears that a module can only use either the two-argument bessel_jn, or the three-argument bessel_jn, but not both.
steve j
steven_j_
Here is a simplified code sample that produces the error. The first subroutine in the module uses the two-argument bessel_jn while the second subroutine uses the three-argument version. When I attempt to compile this module, I get the errors I posted previously.
steve j
module Test_bessel_jn
    contains
subroutine Sub1(n, x, J)
    implicit none
    real*8, intent(in) :: x
    real*8, intent(out) :: J
    J = bessel_jn(n, x)
    return
end subroutine
subroutine Sub2(n, x, J)
    implicit none
    real*8 JB(n+1)
    JB = bessel_jn(0, n, x)
    J = JB(n+1)
    return
end subroutine
end module
Steve_Lionel
I agree that this is a compiler bug. The compiler is getting confused by the appearance of two different forms of BESSEL_JN in the compilation. Please report this to Intel at https://supporttickets.intel.com/?lang=en-US
