Problem Cursor with StandardGraphic
Kaspar_T_
When compiling the short code below with IFORT /libs=qwins Test.F90 the cursor after READ doesn't appear, when a compiler version higher than 2011 Update 5 (package 221) is used. (with /libs=qwin no problems). Is there a way to get the cursor when compiling with versions higher than 2011 update 5? ! Compiler options: /libs:qwin --> QuickWin ; /libs:qwins --> StandardGraphic PROGRAM TESR USE IFQWIN IMPLICIT NONE INTEGER*2 L INTEGER K TYPE(WINDOWCONFIG) SCREEN ! MAX. RESOLUTION SCREEN.NUMXPIXELS=-1; SCREEN.NUMYPIXELS=-1 SCREEN.NUMTEXTCOLS=-1; SCREEN.NUMTEXTROWS=-1 SCREEN.NUMCOLORS=-1 SCREEN.FONTSIZE=-1 SCREEN.TITLE= " "C K=SETWINDOWCONFIG(SCREEN) ! Terminates the application without displaying a message box K=SETEXITQQ(QWIN$EXITNOPERSIST) ! CURSOR 1/4 HIGHT, CURSOR ON L=SETTEXTCURSOR(Z'0802') L=DISPLAYCURSOR($GCURSORON) L=INITIALIZEFONTS( ) 11 WRITE(6,'(//'' TEST > '',$)') READ(5,'(I5)',ERR=11) K END PROGRAM SPIPLO
I can reproduce the problem and see the change in behavior between 2011 Update 5 and 2011 Update 6 (the latter is compiler version 12.1). I've escalated this to development as issue DPD200252709 and will let you know of any progress.
