28381 Discussions
Problem comes after installed w_fc_c_9.0.025_IA32.exe
Zhanghong_T_
Hi all,
After I installed this version and recompile the same project, the following dialog appears when I run my program:
Can anyone tell me how to solve this problem?
Zhanghong Tang
TimP
When you run a dynamic linked .exe, the Intel compiler library folder must be on the library path. If you don't wish to take the installation option to add it always to the path, you can run from the window opened by the start menu shortcut to ifortvars.bat, or from Visual Studio Fortran setup.
Zhanghong_T_
Thank you very much!
