29650 Discussions
Problem running Intel Fortran with IMSL
Li__Jun
Could someone please help on an issue I have when running a Fortran program that uses IMSL?
I installed Fortran and IMSL on a PC. I followed the steps in installing Intel Visual Fortran Composer XE for windows, and then IMSL with the license file. I also configurate for use from Microsoft Visual Studio by adding the directory of IMSL to the Libraries and Includes.
Now when I ran the program on this machine, I received the following error message: "The procedure entry point mkl_serv_set_progress_interface could not be located in the dynamic link library C:\Program Files (x86)\VNI\imsl\fnl701\Intel64\lib\imslmkl_dll.dll."
The exact same program can be run at another machine. Any comments? Thanks.
Steve_Lionel
You will need to copy the named MKL DLL to the other system, probably in the same folder as your EXE. I am not aware that MKL has a redistributable installer. As an alternative, you can select an IMSL build that links to the static IMSL and MKL libraries.
Steve_Lionel
Li__Jun
Dear Steve,
Thank you so much for your super quick reply and suggestion.
Regarding your first solution, did you mean the following: Copy the imslmkl_dll.dll and imslmkl_dll.lib (located at C:\Program Files (x86)\VNI\imsl\fnl600\intel64\lib) from the computer that runs the program well to the computer (same directory) that just finished installation?
Sorry I am not familiar with these topics so I would greatly appreciate if you could confirm my understanding.
Best,
Jun
Li__Jun
I copied the folder from one computer to the other one. It runs without any problem now.
Thanks again, Steve.
mecej4
Li_Jun:
It appears that you have two versions of IMSL installed:
Version 7.01 at C:\Program Files (x86)\VNI\imsl\fnl701\...
and
Version 6.00 at C:\Program Files (x86)\VNI\imsl\fnl600\...
You may run into problems if you build using the libraries of one version and the EXE that you built finds DLLs from the other version. There is no reason to keep Version 6.00 of IMSL if you have Version 7.01, unless you work in a support role and have to support a mix of Version 6 and Version 7 users.
Li__Jun
Great catch. I did not even notice the difference.
These two versions show up at two different computers, not one. But after I copied the dll files from the computer with 6.00 version to the computer with 7.01 version, the Fortran program runs perfectly fine.
In any way, thank you for the comment.
