29657 Discussions
Problem with MOLD keywork in ALLOCATE
MR
when I try to compile the attached code I see the following error:
ifort test-ifort.f90 -o test-ifort
/tmp/ifort9y3yNI.o:(.rodata+0x50): undefined reference to `i_rhs_'
however up to my understanding the code is correct (and it compiles
with gfortran).
ifort -V
Intel Fortran Intel 64 Compiler XE for applications running on
Intel 64, Version 12.0.4.191 Build 20110427
Is this a compiler problem?
Thank you,
Marco
[fortran]module mod_ti
 implicit none
 public :: c_ode, i_rhs
 private
 type, abstract :: c_ode
 contains
  procedure(i_rhs), deferred, pass(uuu) :: rhs
 end type c_ode
 abstract interface
  pure subroutine i_rhs(tnd,uuu)
   import :: c_ode
   implicit none
   class(c_ode), intent(in)  :: uuu
   class(c_ode), intent(out) :: tnd
  end subroutine i_rhs
 end interface
end module mod_ti
module mod_ee
 use mod_ti, only: c_ode, i_rhs
 implicit none
 public :: ee
contains
 pure subroutine ee(ynew,ynow)
  class(c_ode), intent(in)  :: ynow
  class(c_ode), intent(out) :: ynew
  class(c_ode), allocatable :: tnd
   ! if the following two lines are eliminated the code compiles
   allocate(tnd,mold=ynow)
   deallocate(tnd)
   call ynow%rhs(ynew)
 end subroutine ee
end module mod_ee
module mod_pb
 implicit none
 public :: t_ode, pb_rhs
 type, extends(c_ode) :: t_ode
  real :: y(3)
 contains
  procedure, pass(uuu) :: rhs => pb_rhs
 end type t_ode
contains
 pure subroutine pb_rhs(tnd,uuu)
  class(t_ode), intent(in)  :: uuu
   select type(tnd)
    type is(t_ode)
     tnd%y = -3.0*uuu%y
   end select
 end subroutine pb_rhs
end module mod_pb
program ode_test
 use mod_pb, only: t_ode
 use mod_ee, only: ee
 implicit none
 type(t_ode) :: a, b
 a%y = (/ 1.0 , 2.0 , 3.0 /)
 call ee(b,a)
end program ode_test
[/fortran]
Yes, it is a compiler problem that is fixed in a future update (probably September). The bug involves an abstract type with a deferred type-bound procedure. In some cases, the compiler erroneously generates an external reference to the deferred procedure name. The issue ID for this is DPD200169377 in case you want to watch for it in the list of fixed bugs.
MR
OK, thank you.
Marco
