29602 Discussions
Problem with array mixing C++ and Fortran
Juan_David_V_
Hello.
I have a Fortran static Library with one subroutine. I call that subroutine from C++ and I pass one array, inside the subroutine the array change its values but when I use it again in C++ I just get a single value.
Here it's the code
C++
#include "stdafx.h"
#include "iostream"
using namespace std;
extern "C"{
	void LIBRERIA(int *ENTERO, double *DOBLE, double *ARREGLO);
int _tmain(int argc, _TCHAR* argv[])
	int ent = 5;
	double dou = 2;
	double arre[5];
	LIBRERIA(&ent, &dou, arre);
	cout << *arre << endl;
Fortran subroutine
Subroutine Libreria(entero, doble, arreglo)
    implicit none
    integer entero
    double precision doble, numerito
    double precision, dimension(entero) :: arreglo
    print*, "Inside the library"
    numerito = entero * doble
    arreglo(:) = numerito
    print*, arreglo
    End subroutine
Thanks for any help.
IanH
Your C++ code is only writing a single value to the console.  If you want to write all the elements of `arre`, then you need a loop or similar.
#include "stdafx.h"
#include <iostream>
extern "C"{
	int ent = 5;
	double dou = 2;
	double arre[5];
	for (int i = 0; i < ent; ++ i) cout << arre << endl;
For robustness, you should consider using Fortran 2003's C interoperability features in your Fortran code.
