Problem with created thread
charles_d_
I'm trying to write a tcp/ip server that create new thread on each new connection.
The problem I'm facing is that the thread are correctly created, but as soon as one thread is requested to stop (upon connection drop for exemple) all thread are stopped.
The problem do not occur if the thread have nothing to do with communication.
here below is my source code, if the variable switch in routine DC_DEMARRE_SERVEUR have for value 1 then the thread created have nothing to do with communication and created thread stop automaticaly after a certain period, keeping the other thread alive.
If the variable switch in routine DC_DEMARRE_SERVEUR have for value 2 then the thread created are receiving message via TCP/IP and for test also stop after a certain period, but in that case, the first thread being stop, will stop all the thread!! I can not figure out why.
Could somebody help me?
!> @brief      Program .
!> @details    .
!> @return     none
      PROGRAM MTCOM
      USE KERNEL32
      USE WS2_32
      implicit none
      !        INCLUDED FILES
      !        LOCAL DATA
      logical*1      FOREVER /.TRUE./
      INTEGER (KIND = 4) ::  WDG_DELAY_S = 10                    ! activate watchdog every seconds
      real*4         ellapsed_time
      integer*2      portDisponible
      INTEGER*4      exit_code
      integer*4      i,status
      INTEGER*4      rcvsize
      INTEGER*4      BUFFER
      logical*1      DC_DEMARRE_SERVEUR
cx-----------------------------------
      INTEGER WINSOCK_V2_2
      INTEGER CONNECTION_DROPPED_BY_REMOTE_PARTY
      INTEGER SUCCESS
      PARAMETER(WINSOCK_V2_2 = X'202',CONNECTION_DROPPED_BY_REMOTE_PARTY = X'05050505',SUCCESS = 0)
      TYPE(T_SOCKADDR_IN) listenerInfo,listener1Info
      TYPE(T_SOCKADDR_IN) connectionInfo
      TYPE(T_WSADATA) wsaInfo
      TYPE(T_FD_SET) writeset
      TYPE(T_FD_SET) readset
      TYPE(T_timeval) timeset
      TYPE T_CLIENT_SERVER_MESSAGE
      SEQUENCE
        UNION
          MAP
            INTEGER Code
            INTEGER dest
            INTEGER msgSize
            UNION
              MAP
                CHARACTER*16 dest_buffer
              END MAP
              MAP
                INTEGER dest_code
                CHARACTER*12 msg_content
              END MAP
            END UNION
          END MAP
          MAP
            CHARACTER*1048 buffer
          END MAP
        END UNION
      END TYPE
      TYPE(T_CLIENT_SERVER_MESSAGE) clientServerMessage
      INTEGER connection,nb_connection
      INTEGER*4 connection_list(10) /10*-1/
      INTEGER ioctlsocket_bck /-1/
      INTEGER listener,NonBlock
      CHARACTER*16 host
      INTEGER*2 port
      INTEGER SendMsg
      INTEGER ReceiveMsg
      INTEGER fd_zero(64)
      data fd_zero /64*0/
      integer*4       block_t
      integer*4       nb_thread /0/
      logical*1 IS_THREAD_SERVEUR_ALIVE
      logical*1 connection_found
      structure /threadinfo/
        integer(INT_PTR_KIND()) ThreadHandle1
        integer*4               id
        integer*4               duration
        integer*4               listener
        integer*4               connection
        CHARACTER*16            host
        INTEGER*2               port
        logical*1               stopth
        logical*1               startwork
        logical*1               THREAD_START_REQ
      end structure
      record /threadinfo/thread_r(10)
      common/thread/thread_r
      !        CODE
      !initialization  :
        ! Winsock v2. not initialized
        listener  = INVALID_SOCKET
        connection = SOCKET_ERROR
        host = '127.0.0.1'
        port = 5000
        ellapsed_time = SECNDS(0.0)   ! initialized ellapsed_time
          ! Initialize Winsock v2. if needed
 10        IF (listener .EQ. INVALID_SOCKET) THEN
            status = WSAStartup(WINSOCK_V2_2, wsaInfo)
            IF (status .NE. SUCCESS) THEN
              write(6,'(" WSAStartup error -",I6)')status
            ENDIF
            listener = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP)
              write(6,'(" socket error - ",I6)')INVALID_SOCKET
              status = WSACleanup()
              GOTO 10
            ELSE
              listenerInfo%sin_family = AF_INET
              listenerInfo%sin_port = htons(port)
              listenerInfo%sin_addr%s_addr = inet_addr(host(1:LEN_TRIM(host)))
              status = bind(listener,%REF(listenerInfo),SIZEOF(listenerInfo))
              IF (status .EQ. SOCKET_ERROR) THEN
                write(6,'(" bind error- - ",I6)')WSAGetLastError()
                GOTO 10
              ENDIF
            ENDIF
          ENDIF
          IF (listener .NE. INVALID_SOCKET) THEN
            status = listen(listener, 5)
                write(6,'(" listen error- - ",I6)')WSAGetLastError()
              GOTO 10
            ENDIF
            ! Change the socket mode on the listening socket from blocking to
            ! non-block so the application will not block waiting for requests
            NonBlock = 1
            status = ioctlsocket(listener, FIONBIO,%ref(NonBlock))
            if (status .EQ. SOCKET_ERROR) THEN
              ioctlsocket_bck = status
                write(6,'(" ioctlsocket failed with error- - ",I6)')WSAGetLastError()
            ELSE
              if (ioctlsocket_bck .ne. status) then
                write(6,'(" ioctlsocket is OK!")')
                readset%fd_count = 0
                readset%fd_array = fd_zero
                writeset%fd_count =0
                writeset%fd_array = fd_zero
                readset%fd_count = 1
                readset%fd_array(1) = listener
                timeset%tv_sec = 0
                timeset%tv_usec= 100000
                status = select(0,%ref(readset),%ref(writeset),0,%ref(timeset))
                  write(6,'(" Select failed with error- - ",I6)')WSAGetLastError()
                end if
              end if
              nb_connection = 0
              DO WHILE (nb_connection.le.10)
                connection = accept(listener,%REF(connectionInfo),0)
                if (connection .gt. 0 ) then
                  connection_found =.false.
                  do i=1,10
                    if ((connection.eq.connection_list(i)).and.(connection_list(i).ne.-1)) then
                      connection_found = .true.
                    end if
                  end do
                  if (.not.connection_found) then
                    write(6,'(" New connection - ",I6," on list ",i6)')connection,listener
                    nb_connection =nb_connection+1
                    thread_r(nb_connection).listener = listener
                    thread_r(nb_connection).connection = connection
                    thread_r(nb_connection).duration = nb_connection*25
                    if (.not.DC_DEMARRE_SERVEUR(nb_connection)) then
                      write(6,'(" Fail to start thread nb ",i6)')nb_connection
                    end if
                  end if
                end if
              END DO
            ENDIF
          ENDIF
      END
      logical*1 FUNCTION DC_DEMARRE_SERVEUR(threadnb)
      USE IFPORT
      USE IFCORE
      use IFMT
      implicit none
      INTERFACE
       integer(4) FUNCTION Thread_Proc2(lpThreadParameter)
       !DEC$ ATTRIBUTES STDCALL,ALIAS:"_thread_proc2" :: Thread_Proc2
       integer(INT_PTR_KIND()) lpThreadParameter
       END FUNCTION
      END INTERFACE
      INTERFACE
       integer(4) FUNCTION Thread_Proc1(lpThreadParameter)
       !DEC$ ATTRIBUTES STDCALL,ALIAS:"_thread_proc1" :: Thread_Proc1
       END FUNCTION
      END INTERFACE
      CHARACTER*1 kbd
      INTEGER(KIND=INT_PTR_KIND( )) handle,handle1
      logical*4  stopth,startwork
      integer*4 exit_code,i,j,iretlog,iretint,timedate
      INTEGER*4 threadnb,switch
        integer*4               id
        integer*4               duration
        integer*4               listener
        CHARACTER*16            host
        INTEGER*2               port
        logical*1               stopth
        logical*1               startwork
      end structure
      switch = 2
      thread_r(threadnb).stopth = .false.
      thread_r(threadnb).startwork =.false.
      thread_r(threadnb).THREAD_START_REQ =.true.
      if (switch.eq.1) then
        ThreadHandle1 = CreateThread(0,0,Thread_Proc1,loc(threadnb),CREATE_SUSPENDED,thread_r(threadnb).id)
      else
        ThreadHandle1 = CreateThread(0,0,Thread_Proc2,loc(threadnb),CREATE_SUSPENDED,thread_r(threadnb).id)
      end if
      iretlog = SetThreadPriority(ThreadHandle1,THREAD_PRIORITY_BELOW_NORMAL )
      iretint = ResumeThread(ThreadHandle1)
      WRITE(6,*)" THREAD ",threadnb," Nb ",ThreadHandle1," ID ",thread_r(threadnb).id," CREATED"
      i=0
      iretlog = GetExitCodeThread( ThreadHandle1, exit_code )
      if(exit_code.eq.STILL_ACTIVE) then
        thread_r(threadnb).ThreadHandle1 = ThreadHandle1
        DC_DEMARRE_SERVEUR = .TRUE.
      else
        DC_DEMARRE_SERVEUR = .FALSE.
      endif
      END FUNCTION DC_DEMARRE_SERVEUR
      logical*1 FUNCTION IS_THREAD_SERVEUR_ALIVE(threadnb)
      USE IFPORT
      USE IFCORE
      use IFMT
      implicit none
      integer*4 exit_code,iretlog
      INTEGER*4 threadnb
        integer*4               id
        integer*4               duration
        integer*4               listener
        CHARACTER*16            host
        INTEGER*2               port
        logical*1               stopth
        logical*1               startwork
      end structure
      iretlog = GetExitCodeThread( thread_r(threadnb).ThreadHandle1, exit_code )
        IS_THREAD_SERVEUR_ALIVE = .TRUE.
      else
        IS_THREAD_SERVEUR_ALIVE = .FALSE.
      endif
      END FUNCTION IS_THREAD_SERVEUR_ALIVE
      integer(4) function Thread_Proc2(lpThreadParameter)
      !DEC$ ATTRIBUTES STDCALL, ALIAS:"_thread_proc2" :: Thread_Proc2
      USE IFCORE
      USE IFMT
      USE WS2_32
      implicit none
      INTEGER*4 threadnb
      POINTER(parg,threadnb)
      INTEGER*4 i
      INTEGER*4 threadID,index
      real*4 t,delta
      INTEGER (KIND = 4) ::  WDG_DELAY_S = 5                    ! activate watchdog every seconds
      integer*4      status
      integer*4      rcvsize
      INTEGER*4      BUFFER
      INTEGER SUCCESS
      PARAMETER(CONNECTION_DROPPED_BY_REMOTE_PARTY = X'05050505',SUCCESS = 0)
      SEQUENCE
        UNION
          MAP
            INTEGER Code
            INTEGER dest
            INTEGER msgSize
            UNION
              MAP
              END MAP
              MAP
                INTEGER dest_code
              END MAP
            END UNION
          END MAP
          MAP
          END MAP
        END UNION
      END TYPE
      INTEGER connection
      INTEGER SendMsg
      INTEGER ReceiveMsg
      integer*4       counter
        integer*4               id
        integer*4               duration
        integer*4               listener
        CHARACTER*16            host
        INTEGER*2               port
        logical*1               stopth
        logical*1               startwork
      end structure
      parg = lpThreadParameter
      write(6,*) "The value of the Thread_Proc1 argument is ",threadnb
        threadID = GetCurrentThreadId()
        write(6,'(" NS THREAD ID -",I12)')threadID
        do i=1,10
          if (thread_r(i).id.eq.threadID) then
            index = i
          end if
        end do
        write(6,*) " START SERVER PART OF THREAD ---- ",index," Nb ",thread_r(index).ThreadHandle1, " ID ",thread_r(index).id
        t = SECNDS(0.0)
        write(6,*) "reset t ",t,' for thread ',thread_r(index).id
        counter = 0
        FOREVER = .TRUE.
        connection = thread_r(index).connection
        DO WHILE (FOREVER)
          if (thread_r(index).STOPTH) THEN
            write(6,'(" NS ",i6," END REQUESTED -",I6)')threadID,counter
            FOREVER = .FALSE.
          end if
          if (INT(SECNDS(ellapsed_time))>WDG_DELAY_S) THEN
            write(6,'(" NS ",i6," ID ",i6," counter -",I6," connection ",i6)')index,threadID,counter,connection
            counter = counter + 1
            ellapsed_time = SECNDS(0.0) ! reset ellapsed_time
          end if
          delta = SECNDS(t)
          if (delta.gt.thread_r(index).duration) then
            write(6,*) "got t ",delta,' for thread ',thread_r(index).id,' index',index,' > ',thread_r(index).duration
            FOREVER = .FALSE.
          end if
          call sleepqq(100)
          status = ReceiveMsg(connection,clientServerMessage%buffer,1048,rcvsize)
          IF (status .EQ. SUCCESS) THEN
100         continue
            if (rcvsize.le.SIZEOF(clientServerMessage)) then
               write(6,'(" NS ReceiveMsg - ",A6)')clientServerMessage%buffer(6:8)
               if (clientServerMessage%buffer(6:8).eq.'000') then
		         WRITE (clientServerMessage%buffer,'(A9,I4.4)') '0013/100/',5000
                 status = SendMsg(connection,clientServerMessage%buffer(1:13),13)
                 write(6,'(" NS SendMsg - ",I6)')status
               end if
            else
            end if
          ELSE IF (status .EQ. 10035) THEN  !nothing to read
cdg       WRITE(*, *) 'nothing to read - ', status
          ELSE
            IF (status.EQ.CONNECTION_DROPPED_BY_REMOTE_PARTY) THEN
              write(6,'(" NS ReceiveMsg - Connection dropped by remote party")')
              write(6,'(" NS ",i6," ID ",i6," STOP SERVEUR - connection ",i6)')index,threadID,connection
              FOREVER = .FALSE.
            ELSE
              write(6,'(" NS ReceiveMsg - ",I6)')status
            ENDIF
cdg            status = closesocket(connection)
cdg            status = closesocket(listener)
cdg            write(6,'(" NS closesocket - ",I6)')status
cdg            connection = SOCKET_ERROR
          ENDIF
        END DO
      write(6,*) " END OF THREAD soon---- ",index," Nb ",thread_r(index).ThreadHandle1," ID",thread_r(index).id
      call sleepqq(10000)
      write(6,*) " END OF THREAD now ---- ",index," Nb ",thread_r(index).ThreadHandle1," ID",thread_r(index).id
      Thread_Proc2 = 0
      call EXITTHREAD(0)
      end function
      integer(4) function Thread_Proc1(lpThreadParameter)
      !DEC$ ATTRIBUTES STDCALL, ALIAS:"_thread_proc1" :: Thread_Proc1
      USE IFPORT
      USE IFCORE
      USE IFMT
      implicit none
      INTEGER*4 threadnb
      INTEGER*4 i
      real*4 t
        integer*4               id
        integer*4               duration
        integer*4               listener
        CHARACTER*16            host
        INTEGER*2               port
        logical*1               stopth
        logical*1               startwork
      end structure
      do i=1,10
          index = i
        end if
      end do
      CALL NEWSERVEUR1(index)
      call sleepqq(10000)
      Thread_Proc1 = 0
      call ExitThread(0)
      end function
      SUBROUTINE NEWSERVEUR1(threadnb)
      use psapi
      USE IFPORT
      USE KERNEL32
      USE WS2_32
      implicit none
      INTEGER*4      exit_code,threadnb
      real*4         t,delta
      integer(DWORD)  :: threadID
      integer*4     duration,index
        integer*4               id
        integer*4               duration
        integer*4               listener
        CHARACTER*16            host
        INTEGER*2               port
        logical*1               stopth
        logical*1               startwork
      end structure
      !        CODE
cdg      threadID = GetCurrentThreadId()
cdg      do i=1,3
cdg        if (thread_r(i).id.eq.threadID) then
          duration = thread_r(threadnb).duration
          write(6,*) "Assign duration ",duration,' for thread ',thread_r(threadnb).id
          t = SECNDS(0.0)
          write(6,*) "reset t ",t,' for thread ',thread_r(threadnb).id
          index = threadnb
cdg        end if
cdg      end do
      DO WHILE (.TRUE.)
        call sleepqq(200)
        delta = SECNDS(t)
        if (delta.gt.duration) then
          write(6,*) "got t ",delta,' for thread ',thread_r(threadnb).id,' index',index,' > ',duration
          goto 9999
        end if
      ENDDO
 9999 CONTINUE
      write(6,*) "Stop thread ",threadnb,'ID ',thread_r(threadnb).id
      RETURN
      END
!> @brief      FUNCTION SendMsg.
!> @details    send message via TCP/IP communication.
!> @return     none
      INTEGER FUNCTION SendMsg(connection, buffer, size)
      USE WS2_32
      IMPLICIT NONE
      INTEGER SUCCESS
      PARAMETER(SUCCESS = 0)
      INTEGER connection
      INTEGER size
      CHARACTER*(size) buffer
      INTEGER bytesSent
      INTEGER bytesSentTotal
      INTEGER status
      SendMsg = SUCCESS
      bytesSent = 0
      bytesSentTotal = 0
      DO WHILE (bytesSentTotal < size)
        bytesSent = send(connection,
     +                   buffer(bytesSentTotal + 1:bytesSentTotal + 1),
     +                   (size - bytesSentTotal),
     +                   0)
        IF (bytesSent .EQ. SOCKET_ERROR) THEN
          SendMsg = WSAGetLastError()
          RETURN
        ENDIF
        bytesSentTotal = bytesSentTotal + bytesSent
      END DO
      RETURN
      END
!> @brief      FUNCTION ReceiveMsg.
!> @details    Receive message via TCP/IP communication.
!> @return     none
      INTEGER FUNCTION ReceiveMsg(connection, buffer, size,rcvsize)
      USE WS2_32
      IMPLICIT NONE
      INTEGER SUCCESS
      INTEGER connection
      INTEGER size,rcvsize
      INTEGER bytesReceived
      INTEGER bytesReceivedTotal
      INTEGER status
      ReceiveMsg = SUCCESS
      bytesReceived = 0
      bytesReceivedTotal = 0
      DO WHILE (bytesReceivedTotal < size)
        bytesReceived = recv(connection,
     +                       buffer(bytesReceivedTotal + 1:bytesReceivedTotal + 1),
     +                       (size - bytesReceivedTotal),
     +                       0)
        IF (bytesReceived .EQ. SOCKET_ERROR) THEN
          ReceiveMsg = WSAGetLastError()
          rcvsize = bytesReceivedTotal
          If ((ReceiveMsg.eq.10035).and.(bytesReceivedTotal.gt.0)) then
            ReceiveMsg = 0
          end if
          RETURN
        ELSEIF (bytesReceived .EQ. 0) THEN
          ReceiveMsg = CONNECTION_DROPPED_BY_REMOTE_PARTY
          RETURN
        ENDIF
        bytesReceivedTotal = bytesReceivedTotal + bytesReceived
      END DO
      RETURN
      END
IanH
Some of your local variables in your procedures implicitly have the SAVE attribute because they have initialization - in particular the variable FOREVER, which controls whether the thread procedure continues looping or not.  SAVE'd variables are typically implemented using static storage (rather than being stored on the stack), because static storage is used that variable will be shared amongst all threads, as soon as one thread sets it to .FALSE., all threads will exit.
The style of the code makes it very difficult to follow.
jimdempseyatthecove
You should not call ExitThread to terminate the thread. Instead, you should return from the thread entry point function. (IOW have error returns from any nested functions called from your thread startup/entry point function.
Jim Dempsey
IanH
You also need to make sure that you compile with the necessary options to make your thread procedures re-entrant (perhaps also add RECURSIVE).
charles_d_
Thanks for the answer but:
1 - making the recursive option do not change anything on the behavior, with or without this option if switch = 1 stopping one thread do not stop the other witch is correct, but with swicth=2, stopping one thread do stop all the thread witch is not correct.
2 - I do not understand how to stop thread whitout using exitthread function, As far as I understand this is the normal way to stop thread when we whan that the thread do not exist anymore.
IanH
charles_d_
​Thanks IanH, that was the point, removing the initialization of FOREVER do solve my Pb.
