Problem with finalizer
Li_Dong
Dear all,
I want to use the final bounding to clean a linked list, the simple example is:
[fortran]module TypeDef
    implicit none
    type A
        integer :: id = -1
        type(A), pointer :: next => null()
    contains
        final :: A_clean
    end type A
contains
    subroutine A_clean(this)
        type(A), intent(inout) :: this
        print *, "Clean element", this%id
        if (associated(this%next)) deallocate(this%next)
    end subroutine A_clean
end module TypeDef
program TBPFinal
    use TypeDef
    implicit none
    type(A), pointer :: head
    allocate(head)
    head%id = 1
    allocate(head%next)
    head%next%id = 2
    deallocate(head)
end program TBPFinal[/fortran]
When I compile it with ifort 12, it complains:
ifort: error #10106: Fatal error in /opt/intel/composerxe-2011.0.085/bin/ia32/fortcom, terminated by segmentation violation
compilation aborted for TBPFinal.f90 (code 1)
Any idea? I also changed the attribute of "head" from "pointer" to "allocatable", since the document says:
A data entity is finalizable if it is of a finalizable type and is not a pointer.
dongli
Xiaoping_D_Intel
It is a compiler bug. I will submit a bug report and keep you posted.
Xiaoping Duan
Intel Customer Support
jahern
I just encountered a similar problem when creating a linked list type - possibly the same. The reduced code is:
[fortran]MODULE err
   IMPLICIT NONE
   TYPE Object
      TYPE(Object), POINTER :: next => NULL()
   CONTAINS
      FINAL :: Finalize_Object
   END TYPE Object
CONTAINS
   SUBROUTINE Finalize_Object(self)
      TYPE(Object), INTENT(INOUT) :: self
      DEALLOCATE(self%next)
   END SUBROUTINE Finalize_Object
END MODULE err[/fortran]
The error I obtained was nearly the same, but with a different platform and version:
[plain]fort: error #10106: Fatal error in /opt/intel/composerxe-2011.1.107/bin/intel64/fortcom, terminated by segmentation violation
compilation aborted for error.F90 (code 1)[/plain]
This error occurred when compiling the above on Fedora 14 x64 with ifort12.0.0 20101116 froml_fcompxe_intel64_2011.1.107. Hopefully this will help with the diagnosis!
Jared Ahern
pbkenned1
Both of the examples in this thread are resolved in Composer XE update #6 (aka 12.1 compiler). The packages containing the fixes are:
l_fcompxe_2011.6.233
m_fcompxe_2011.6.038
w_fcompxe_2011.6.233
The first example produces:
>ifort U79148.f90
Intel Visual Fortran Intel 64 Compiler XE for applications running on Intel 64, Version 12.1.0.233 Build 2011081
-out:U79148.exe
>U79148.exe
Clean element 1
Clean element 2
Patrick Kennedy
jimdempseyatthecove
It should be noted that your finalize routine could be potentially called explicitly, say to truncate your list at some point, therefor consider adding a nullify for the line pointer.
Jim Dempsey
