Last week after information of an available update 6 to version 19 of Intel FORTRAN. After an apparently successful installation Visual Studio would not recognize my VFPROF files. After checking online and following debug instruction I was able to use the integrate command to register 4 dll's and VS2017 now works (I have not tried VS2019 yet). However, when I load VS2017 I receive an error warning (which I can apparently ignore at the moment with no consequences). The activity log records this as
System.IO.FileNotFoundException: The system cannot find the file specified. (Exception from HRESULT: 0x80070002) at Intel.CommonTools.CompilerReportProvider.UpdateCompilerToolWindows(EventKind event, Boolean showPane) at Intel.CommonTools.Annotations.AnnotationFactory.UpdateAnnotationTags() at Intel.CommonTools.Annotations.AnnotationFactory.OnLayoutChanged(Object sender, TextViewLayoutChangedEventArgs e) at Microsoft.VisualStudio.Text.Utilities.GuardedOperations.RaiseEvent[TArgs](Object sender, EventHandler`1 eventHandlers, TArgs args) --- End of stack trace from previous location where exception was thrown --- at Microsoft.VisualStudio.Telemetry.WindowsErrorReporting.WatsonReport.GetClrWatsonExceptionInfo(Exception exceptionObject)
I have two questions.
1 Any guesses on what probably happened during installation and will it happen again nest time I install. I did find much later that a vfproj file was somehow hung up in my system
2 Any suggestions on what I need to do about the error message would be appreciated?
Ian
My usual suggestion of an uninstall and reinstall generally clears up such issues.
