29657 Discussions
Problem with user-defined derived type I/O
johnyb_
I can not get this code working, but I fail to understand what I'm doing wrong:
module m_test
    type t1
        integer :: a
      contains
        procedure, private :: r_t1
        generic :: read(formatted) => r_t1
    end type
    type, extends(t1) :: t2
        integer :: b
    end type
    contains
        subroutine r_t1(dtv, unit, iotype, vlist, iostat, iomsg)
            class(t1),          intent(inout)   :: dtv
            integer,            intent(in)      :: unit
            character(len=*),   intent(in)      :: iotype
            integer,            intent(in)      :: vlist(:)
            integer,            intent(out)     :: iostat
            character(len=*),   intent(inout)   :: iomsg
            integer i,j
            select type (dtv)
                type is (t2)
                    read(unit, fmt="(2i4)", iostat=iostat, iomsg=iomsg) dtv%a , dtv%b
                    print *, "a:",dtv%a, ", b:", dtv%b
                class default
                    read(unit, fmt="(i4)", iostat=iostat, iomsg=iomsg) dtv%a
                    print *, "a:",dtv%a
            end select
        end subroutine
end module
program test
    use m_test
    character(len=:), allocatable :: str
    type(t1) :: x
    type(t2) :: z
    str="123456789"
    read(str, fmt="(DT)") x
    print *, x%a
    read(str, fmt="(DT)") z
    print *, "z"
    print *, z%a
    print *, z%b
end program
It compiles ok, but produces a run-time error:
C:\TEMP>ifort test.f90 /standard-semantics
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.4.221 Build 20150407
Copyright (C) 1985-2015 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 11.00.61030.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:test.exe
-subsystem:console
test.obj
C:\TEMP>test
 a:        1234
        1234
 a:        1234 , b:        5678
forrtl: severe (24): end-of-file during read, unit -5, file Internal Formatted Read
Image              PC                Routine            Line        Source
test.exe           00007FF789348099  Unknown               Unknown  Unknown
test.exe           00007FF789333FDB  Unknown               Unknown  Unknown
test.exe           00007FF78933139F  Unknown               Unknown  Unknown
test.exe           00007FF78939D5EE  Unknown               Unknown  Unknown
test.exe           00007FF789386864  Unknown               Unknown  Unknown
KERNEL32.DLL       00007FF9814816AD  Unknown               Unknown  Unknown
ntdll.dll          00007FF982BC34A5  Unknown               Unknown  Unknown
C:\TEMP>
I'm probably trying to do something that is not allowed, but fail to see my error. Any enlightenment is appreciated
Johny
I think your code is correct. What I see happening is that your UDIO routine is called for Z and then the run-time library tries to read component a separately, which it shouldn't. I will send this on to the developers. Issue ID is DPD200375355.
johnyb_
Thank you Steve,
it is a small consolation that my code is correct. I stumbled upon this problem while trying to create a reproducer for another problem, where the additional component of the second type that extends t1 is read correctly inside the UDTIO procedure, but in the calling program the component has a completely different and wrong content.
Does the problem also occur with the upcoming version 16?
johnyb_
Well, I managed to reduce my original problem code.
instead of the format for reading z:
i put (erroneously) an "a" too much:
 read(str, fmt="(DT,a)") z
then the program does not crash, but the value for the component b is completely off:
C:\TEMP>test
 a: 1234
 1234
 a: 1234 , b: 5678
 z
 1234
 538976313
C:\TEMP>
Now I hope I can find a workaround to this problem, otherwise lots of code rewriting will have to be done.
I admit that I am puzzled by the behavior, as we have had this feature for a while and this is not an unusual operation. I will wait to see what the developers say. You would not want to add an A format item (nor anything else, really)
This has been fixed for the next major version to be released later this year. I have not yet heard if it will also get fixed in a 16.0 update.
johnyb_
Thanks Steve,
we're hoping for a timely update of ifort as this bug needed some ugly workarounds in our code
I am now told that the fix for this will be in Update 3. The fix is in the run-time library - if you linked to the DLL libraries, which is the default, your program should pick it up automatically, though a recompile is never a bad idea.
johnyb_
Thanks Steve,
that is good news. We are linking to the DLL runtime, but our code will need a recompile anyway as we will remove our workarounds for the bug.
