29402 Discussions
Problems with Systemmenu in dialog-applications
faidor
Hi there, the first problem-thread, I bet ;-).
I built a VF6.0 dailog-application for Windows on a WinNT machine. Now I integrated the systemmenu in the dialog (minmize, maximize and close button on the top right corner). Minimizing works, maximizing is intentionally greyed out, but theclosing-button doesnt do anything. I tried to check the manual - found nothing, I tried to check the examples: no result (check "Therm" for example), the clos-button has also no effect.
Can anybody help me? It would be enough to point out, how it works in the "Therm"-example.
Best greetings,
Andre
faidor
Problem solved: You need to have at least a hidden button with the id=IDCANCEL, otherwise, the clos-button will not work. This is at least applicable for dialog-based applications, base on dflogm.f90 (use dflogm).
Thasnk to Jugoslav, who again proved is great knowledge in VF6.0 ;-). Thanks,
Andre
