29487 Discussions
Problems with instalation Fortran Compiler
felipin85
Hi, i'm try installing Intel Fortran Compiler Composer Xe 2011 in Ubuntu (linux). I have in my network ubuntu 10.04 (64 bits). I copy the folder in my desktop, and I open a terminal.
I place myself in dektop with a "cd", then I write the folder of Fortran, in this case, l_fcompxe_2011.0.084, and then ./install.sh
felipe@felipe-laptop:~/Desktop/l_fcompxe_2011.0.084$ sudo ./install.sh
sudo password for felipe:
sudo: ./install.sh: command not found
Other hand,
elipe@felipe-laptop:~/Desktop/l_fcompxe_2011.0.084$ ./install.sh
bash: ./install.sh: Permiso denegado
How can I installing? I was installing in my desktop computer, I don't understand!
Thanks, and Regards
FELIPE RODRGUEZ FONTE
LAS PALMAS, SPAIN
Kevin_D_Intel
There's probably file owner/permission issues with the already expanded l_fcompxe_2011.0.084 directory contents. There's commands I could offer to change permissions but I'd rather not given the risk.
First, exit the sudo session. Next, working under your normal user id, remove your copy of the l_fcompxe_2011.0.084 directory from your /tmp/felipe area and then get a copy of the original l_fcompxe_2011.0.084.tgz. While still working under your normal user id, un-expand the .tgz in your /tmp/felipearea and then proceed starting at step 3 again. Hopefully that works.
If not, then show us the permissions using this: ls -al /tmp/felipe/l_fcompxe_2011.0.084 (assuming that's what you've chosen to name it)
Kevin_D_Intel
Try this instead:
1. Make a directory for yourself in /tmp, like /tmp/felipe
2. Execute: cd /tmp/felipeand then copy the l_fcompxe_2011.0.084 folder into that location or move that copy in home area into this temporary location
3.cd into thecompiler directory:cd l_fcompxe_2011.0.084
4. Execute the command: sudo su
5. Then run the install with just: ./install.sh
felipin85
The response of system is:
(translate:Permission Denied)
Kevin_D_Intel
felipin85
Kevin, Now I finished of install the intel fortran in my netbook. Very thanks, you are the best!
Thanks, Regards
Kevin_D_Intel
Great! Glad to hear that and thank you for the kind words.
