29649 Discussions
Procedure pointer in parameterized derived type
Stephan_S
The following code does not compile with ifort Version 2021.3.0 on MacOS:
module my_mod
implicit none
type my_type(rkind)
integer, kind :: rkind
real(kind=rkind) :: val
procedure(sub_interface), pointer, nopass :: sub => NULL()
end type my_type
abstract interface
subroutine sub_interface(x, y)
real(kind=8), intent(in) :: x
real(kind=8), intent(out) :: y
end subroutine sub_interface
end interface
contains
subroutine bla_my_type_8(m_in,m_out)
implicit none
type(my_type(8)), intent(out) :: m_out
type(my_type(8)), intent(in) :: m_in
! do something here, e.g.
m_out%val = 2*m_in%val
m_out%sub => m_in%sub
end subroutine bla_my_type_8
subroutine sqrt_sub(x, y)
implicit none
y = sqrt(x)
end subroutine sqrt_sub
end module my_mod
program my_prog
use my_mod
implicit none
type(my_type(8)) :: m
real(kind=8) :: x, y
x = 16
m%sub => sqrt_sub
call m%sub(x, y)
write(*,*) 'y =', y
end program my_prog
As an error message, I get:
prog.f90(44): error #8178: The procedure pointer and the procedure target must have matching arguments.
  m%sub => sqrt_sub
prog.f90(45): error #6784: The number of actual arguments cannot be greater than the number of dummy arguments.   [SUB]
  call m%sub(x, y)
compilation aborted for prog.f90 (code 1)
Strangely, if I either remove the subroutine bla_my_type_8 *or* if I use a non-parameterized derived type, everything works as expected.
It may be important to note explicitly here that the above code does not do anything useful. It is the result of me trying to isolate an error in a large project. I also know that the need to use a parameterized derived type (PDT) is not apparent from the example, but PDTs make a lot of sense in the original application this example was distilled from.
Labels (2)
FortranFan
@Stephan_S ,
Per my understanding of the Fortran standard, the errors are due to issues with Intel compiler.  If you have support subscription, please submit a request at Intel OSC: https://supporttickets.intel.com/servicecenter?lang=en-US
Otherwise, you can hope Intel staff will pick up the incident from here.
FortranFan
@Stephan_S ,
Stephan_S
Thanks for the quick reply! I will check if we have support subscription and file a request if possible.
Devorah_H_Intel
Thank you for the report. This issue has been escalated to engineering.
