Program Exception
hydrodyn
I transferred huge computer model from CVF to Intel Fortran.
It does perferct compiling and linking. When I tried to run the program, I get program exception.
I debugged the program and it happens right at the Subroutine statement. I could not figure out as what is causing the problem.
I even commented all other code and kept only the call to the subroutine that is showing exception. But still the same error.
I checked all intiialization with proper array declaration. My suboruitne program has many ENTRY points.
I tried many times so far by checking all options available for compilation. But no luck.
So, I am submitting my request to the forum and am looking for some tips as how I can solve this problem.
Venkat
You haven't told us what the exception is. Please show the complete and exact text of the error message.
hydrodyn
Hi, Thanks for your quick reponse. Hi, Sorry for providing sufficient information. Program stops at a call routine in the main program which is an Entry point in the subrotuine STANDARDFILEOUTPUTS. I just debugged the code and got the following error message in Microsfot Visual Studio Unhandled exception at 0x775515de in GLLVHTModelDbg.exe: 0xC0000005: Access violation writing location 0x00004c81 In console window, I get the following message forrtl: Severe 157: Program Exception - access violation Stack Shows ntdll.dll!775515de() [Frames below may be incorrect and/or missing, no symbols loaded for ntdll.dll] ntdll.dll!775515de() ntdll.dll!7754014e() > GLLVHTModelDbg.exe!STANDARDFILEOUTPUTS() Line 2 + 0xe bytes Fortran First few lines of the subroutine is given below Subroutine StandardFileOutputs ! !Global array variables Use G7Allocmemory Use AllocMemoryWQCBM3DVariables Use AllocMemoryWQDPM3DVariables Use AllocMemoryWQE5M3DVariables Use AllocMemoryWQADD3DVariables Use G7NETCDFAllocMemoryVariables
bmchenry
New Contributor II
the ole Entry point issue! you need to provide some snippets of code for a better understanding. However i would venture to guess that the ENTRY has some variables being passed to/fro? You need to check that they are properly declared and the declarations match between call and called program? Also if you do not have proper initialization of the variables it can cause the program to complain. do you use an interface statement? do more than one routine call that Entry statement?
bmchenry
New Contributor II
Venkat, your response to my comment was received via email with some snippets of code You should post up the snippets to this forum so others can review and add comments (since others may have other comments too!) In looking at the code you have Subroutine StandardFileOutputs (lots of declarations, includes, etc) Save RETURN ! !Write headers for different output files ENTRY KernelOutputHeaders If(VersionControlNumber == 2 .and. itrnvp == 1 .and.itrnvpss == 1) Two areas to look at: 1) Do you call Subroutine StandardFileOutputs first? since if not, then calling the ENTRY may wreak havoc 2) perhaps you have an initialization problem with either VersionControlNumber, itrnvp or itrnvpss? Since if any of them are not initialized then INTEL Fortran may complain (based on your compilation settings of whether to 'automatically initialize' and/or Compaq Fortran may have that as the default? and if those two comments don't help please post the snippets to the forum as then others can look at the code and perhaps offer some additional ideas. b
