Program with simple coarrays hangs
Arjen_Markus
in my quest to find a solution for the problem I posted in the thread "Internal compiler error with lock/unlock", I stumbled upon another problem. Again using Intel Fortran 12.0.3.
Here is the program:
! checkscalar.f90 --
! Check some odd (erroneous) behaviour with scalar coarrays
program checkscalar
implicit none
logical, codimension
  • :: new_results
  • logical, codimension
  • :: ready
  • ready = .false.
    new_results = .true. ! Indicates the image has results available
    write(*,*) 'Image', this_image(), new_results
    sync all
    write(*,*) 'Image2', this_image(), new_results
    ! Collect the found primes in image 1, create new tasks
    ! for all images
    do while ( .not. ready )
    if ( this_image() == 1 ) then
    call collect_results
    endif
    call sleepqq(1)
    enddo
    contains
    ! Subroutine to collect the results from all
    ! images (run by image 1)
    subroutine collect_results
    integer :: i
    integer :: np
    integer :: maxindex
    do i = 1,num_images()
    write(*,*) 'Examine', i, new_results
    enddo
    ready = .true.
    enddo
    end subroutine collect_results
    end program checkscalar
    It does not do much: in image 1 I print the value of new_results and when the
    loop is finished I set the flag ready in all images so that they will stop. At least
    that is my intention.
    The output of one run with this program is:
    Image 6 T
    Image 1 T
    Image 3 T
    Image2 3 T
    Image 7 T
    Image2 7 T
    Image2 6 T
    Image 5 T
    Image 2 T
    Image2 2 T
    Image 4 T
    Image 8 T
    Image2 4 T
    Image2 1 T
    Examine 1 T
    Image2 8 T
    Image2 5 T
    (after a few seconds of no progress at all, I stopped the program)
    So, all 8 images start, image 1 is entering the loop, prints the value of new_results on that
    image, and then hangs - it does not get beyond this!
    Does anyone have any clues? Am I doing something wrong? (Possible, of course, but the
    program is so simple that I can not believe that.)
    Arjen
    Steven_L_Intel1
    It is not that sync all is broken, but for some reason a refernece to the local variable isn't getting the updated value. Issue ID is DPD200168369.
    jimdempseyatthecove
    ?? isn't that the purpose of sync all ??
    Jim
    Steven_L_Intel1
    Well, no - it is also a barrier to continued execution until all images reach that point.
    jimdempseyatthecove
    (toung in cheek)
    Then it appears that one should always use YourCoArrayVariable[yourImageNumber] instead of YourCoArrayVariable whenever some other image could write to YourCoArrayVariable (because sync all, although reportedly not broken, does not update local image of YourCoArrayVariable).
    (toung back where it belongs)
    There may be a race condition in an optimization whereby you omit poling other processes if you "know" no updates to your shared variable(s) were made. (error in code relating to condition variables on Linux). Might be a place to look after you get a reproducer.
    Jim Dempsey
    Steven_L_Intel1
    The problem in the initial post got fixed somewhere along the way - it works now in the current compiler, Composer XE 2011 Update 11.
