Program with simple coarrays hangs
Arjen_Markus
in my quest to find a solution for the problem I posted in the thread "Internal compiler error with lock/unlock", I stumbled upon another problem. Again using Intel Fortran 12.0.3.
Here is the program:
! checkscalar.f90 --
! Check some odd (erroneous) behaviour with scalar coarrays
program checkscalar
implicit none
logical, codimension
  • :: new_results
  • logical, codimension
  • :: ready
  • ready = .false.
    new_results = .true. ! Indicates the image has results available
    write(*,*) 'Image', this_image(), new_results
    sync all
    write(*,*) 'Image2', this_image(), new_results
    ! Collect the found primes in image 1, create new tasks
    ! for all images
    do while ( .not. ready )
    if ( this_image() == 1 ) then
    call collect_results
    endif
    call sleepqq(1)
    enddo
    contains
    ! Subroutine to collect the results from all
    ! images (run by image 1)
    subroutine collect_results
    integer :: i
    integer :: np
    integer :: maxindex
    do i = 1,num_images()
    write(*,*) 'Examine', i, new_results
    enddo
    ready = .true.
    enddo
    end subroutine collect_results
    end program checkscalar
    It does not do much: in image 1 I print the value of new_results and when the
    loop is finished I set the flag ready in all images so that they will stop. At least
    that is my intention.
    The output of one run with this program is:
    Image 6 T
    Image 1 T
    Image 3 T
    Image2 3 T
    Image 7 T
    Image2 7 T
    Image2 6 T
    Image 5 T
    Image 2 T
    Image2 2 T
    Image 4 T
    Image 8 T
    Image2 4 T
    Image2 1 T
    Examine 1 T
    Image2 8 T
    Image2 5 T
    (after a few seconds of no progress at all, I stopped the program)
    So, all 8 images start, image 1 is entering the loop, prints the value of new_results on that
    image, and then hangs - it does not get beyond this!
    Does anyone have any clues? Am I doing something wrong? (Possible, of course, but the
    program is so simple that I can not believe that.)
    Arjen
    mecej4
    I know little about coarrays, but this code segment made me suspicious:
    [fortran]do while ( .not. ready )
      endif
      call sleepqq(1)
    enddo
    [/fortran]
    If the loop is entered and this_image() returns a value different from 1, the loop will do nothing but consume time endlessly. What event would cause the IF block to be executed in this case?
    With a dual-core CPU, I get the output
    [bash] Image           1 T
     Image           2 T
     Image2           1 T
     Examine           1 T
     Image2           2 T
    [/bash]
    and then the program gets stuck in the DO WHILE loop. The last line printed has this_image() equal to 2, so the loop will keep calling SLEEPQQ and do nothing else.
    Arjen_Markus
    The function this_image() returns the unique number belonging to the image.
    The intention of the above fragment is to have image 1 (or thread 1 or ...) examine the
    results produced by all images. In the reduced program I posted there are no actual results,
    but the variable that indicates there are is set to .true. at the start. The only task to be done
    in the routine collect_results is to loop over the images, print the value of new_results on that
    image and then to set the variable ready in all images so that the do-while loop stops.
    In short:
    All images except one should wait for image 1 to set "ready" and then terminate the loop
    and stop the program altogether.
    Unfortunately, image 1 seems to get stuck reading the value of new_result on image 2
    and then the program hangs.
    Arjen
    jimdempseyatthecove
    Regardless of the images /= 1 making itout ofthe loop, image 1 should have been able to run through the "Examine" part for all images. Arjen is pointing out that image 1 is hanging when it should not be hanging.
    Jim Dempsey
    Arjen_Markus
    No news on this issue?
    Arjen
    jimdempseyatthecove
    Arjen,
    Sorry I cannot help further as I do not currently have PS 2011 XE, but I hope to have it shortly (a few weeks). At that point I should be able to run your example program (although not on Mac). Could you describe your test environment: processor/processors, single system/multi-system, connection, OS/OSs, bitness (32/64) version of IVF (Fortran Composer). This would help me in trying to replicate your problem.
    Jim Dempsey
    Arjen,
    You should not use things such as SLEEPQQ in coarray applications. Use the language-provided synchronization features instead. For example:
    [fortran]! checkscalar.f90 --
    program checkscalar
    implicit none
  • :: new_results logical, codimension
  • :: ready ready = .false. new_results = .true. ! Indicates the image has results available write(*,*) 'Image', this_image(), new_results sync all write(*,*) 'Image2', this_image(), new_results ! ! Collect the found primes in image 1, create new tasks ! for all images ! sync all if ( this_image() == 1 ) then call collect_results endif contains ! ! Subroutine to collect the results from all ! images (run by image 1) ! subroutine collect_results integer :: i integer :: np integer :: maxindex do i = 1,num_images() write(*,*) 'Examine', i, new_results enddo end subroutine collect_results end program checkscalar[/fortran]
  • In particular, you can't count on the local "ready" being updated unless there is a synchronization point. That is probably what is doing you in.
    Arjen_Markus
    Hi Jim,
    I run this program on a 64-bits Linux machine with 8 cores.
    I am using the free version of Intel Fortran for Linux, version number 12.0.3.
    Arjen
    Arjen_Markus
    Hi Steve,
    thanks for these comments - still learning my way around coarrays. I will experiment with this.
    Arjen
    jimdempseyatthecove
    Arjen,
    Other than for a learning experience with coarrays there is little reasons for using coarrays on such a system - OpenMP would provide for better performance and ease in programming. The only advantage of using coarrays on that system is the static data size could be larger due to multiple process space and the local data (stack and local process allocatables) are acquired from different process virtual address space. And lack of space for local data would only be a concern if you were running 32-bit applications.
    Jim Dempsey
    While I'll agree that you'd get better performance nowadays with OpenMP on such a system, there is a benefit to using coarrays in that the language rules are simpler and the program will scale to clusters without coding changes. I don't agree that OpenMP is easier, but coarrays definitely have a different model and you have to get your head around that first.
    jimdempseyatthecove
    Ammending my last post. Coarrays potentially make sense on your system (assumption on my part)if you have the new Intel Many Integrated Core (e.g. Knights Ferry) and if coarray programmingis more efficent than alternative means.
    Jim Dempsey
    Arjen_Markus
    The main reason for experimenting with coarrays is indeed understanding the programming model.
    I tried Steve's version of my program and that works fine. However, when I introduced a loop with a "sync all" statement, only the first thread finishes - the ready variable seems not to be updated on any other image.
    program checkscalar
    implicit none
  • :: new_results
  • :: ready
  • ready = .false.
    sync all
    ! for all images
    sync all
    endif
    sync all
    enddo
    write(*,*) 'Image ',this_image(), ' done'
    contains
    integer :: i
    integer :: np
    integer :: maxindex
    enddo
    ready = .true.
    enddo
    What I see in the output is that image 1 finishes after examining all images and the others
    never produce the message "Image n done", despite the "sync all" statements.
    Arjen
    Arjen_Markus
    Found the solution!
    I replaced the sync all statements in the do while loop by sync images statements:
    sync images( * )
    else
    sync images( 1 )
    endif
    enddo
    and then the program finishes nicely. Now with this solution I can continue my experiments
    with the actual program(s).
    Arjen
    jimdempseyatthecove
    Arjen,
    A potential error (not your error) is if the compiler optimization stripped the second sync all in your do loop (i.e. sees one at top and bottom and assumes redundant). If this is the case then potentially the sync all following image 1's collect_results is never called.
    Two things to try
    a) place sync all after do loop
    b) remove first sync all in do loop (forcing sync all to follow collect_results)
    Wouldn't hurt to test both scenarios as you want to discover what is going on as opposed to simply getting the code to work (i.e. don't stop testing if first test succeeds).
    Jim Dempsey
    The optimizer would never remove SYNC statements.
    Rather than use a covariable "ready" and testing it in a loop, use the synchronization tools provided by the language, including locks, critical sections and the various forms of SYNC. It would be an unusual coarray application that needed to use a loop for this.
    The biggest danger of learning coarrays is assuming you can simply translate concepts from shared-memory programming in the past. If you're an MPI programmer, however, it may be an easier transition as coarrays sort of look like one-way MPI.
    Arjen_Markus
    I tried these things and I tried "sync all( stat = istat )" (with a write statement) to convince
    the compiler that this statement is required, but the result was still the same.
    Adding a write statement here and there does clarify _what_ is happening, but not why.
    Image 1 leaves the loop, but all other remain in the loop. It definitely looks if the "ready"
    coarray is not updated. With the "sync image" statement it is. (Actually got my original
    program to work that way)
    Arjen
    There's an open bug report "Write to covariable in other image is not reflected in other image's local copy" which I think is the same as your issue. To see if that's true, try building with -Od and see if that changes the behavior.
    I tried your program with optimization and it seemed to work ok. Another thing to try is to test ready[this_image()] which also avoids the bug.
    Arjen_Markus
    With the statement "do while ( .not. ready[this_image()] )" it does work,and turning offoptimisation with
    -O0 works too.
    Well, that is good to know!
    Arjen
    jimdempseyatthecove
    At least you have a reasonable work around to get you past this issue.
    When I introduce work arounds I also insert a comment with a common unique signature
    ! **hack**
    ! using "( .not. ready[this_image()] )" as opposed to "(.not. ready)"
    ! due to compiler bug
    Then later on, as I get new versions of the compiler, I can locate all the hacks and test to see if bug fixed.
    Also, when fixed, I leave the code in but conditionalized out. You never know if a bug resurfaces.
    This would seem to indicate that sync all is broken, or at least appears broken under this circumstance.
    Jim Dempsey
