28158 Discussions
Protected type variables in modules with submodules
Gripton__Adam
This is a follow on question from https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/610969 in which a compiler bug was raised regarding the treatment of protected data in modules with submodules. I've installed Visual Fortran Compiler 18.0.3.210 [IA-32] and the code snippet from the original forum post does, indeed, now, compile. But when the protected variable is part of a TYPE, it still doesn't. To illustrate, I've amended the code from the original post to include a new variable within a TYPE definition:
module mymod
    implicit none
    integer, protected :: n
    type mytype
        integer :: k
    end type mytype
    type (mytype), protected :: ty
    interface
        module subroutine set_n(i)
            integer, intent(in) :: i
        end subroutine set_n
        module subroutine set_k(i)
        end subroutine set_k
    end interface
end module mymod
submodule(mymod) mymod_i
contains
     n = i
        ty%k = i
end submodule mymod_i
program test
    use mymod
    implicit none
    integer :: i
    i = 5
    call set_n(i)
    call set_k(i)
    print *,n
    print *,ty%k
end program test
When I try and compile this, the same error is raised as in the original post:
error #7986: A use associated object that has the PROTECTED attribute shall not appear in a variable definition context.
Is this a further bug, or am I doing something wrong?
Many thanks in advance.
Gripton__Adam
It also doesn't like it if you assign pointers to even standard-type variables that are protected but should be SUBMODULE-accessible:
module mymod
    implicit none
    integer, protected, target :: n
    interface
        module subroutine set_pn
        end subroutine set_pn
    end interface
end module mymod
contains
     n = i
        integer, pointer :: pn
        pn => n
This produces the following compiler error:
error #7994: A use associated object that has the PROTECTED attribute shall not appear as a target in a pointer-assignment-stmt.
FortranFan
You may want to submit support requests with Intel: https://supporttickets.intel.com/?lang=en-US
Gripton__Adam
I've logged it with support. I still think it's a compiler bug. In the original post from https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/610969 a very similar problem was identified as such and the compiler fixed accordingly.
