29616 Discussions
Protected variables in modules with sub-modules
Simon_Geard
module mymod
    implicit none
    integer, protected :: n
    interface
        module subroutine set_n(i)
            integer, intent(in) :: i
        end subroutine set_n
    end interface
end module mymod
submodule(mymod) mymod_i
contains
	    n = i
end submodule mymod_i
program test
    use mymod
    implicit none
    integer :: i
    i = 5
    call set_n(i)
    print *,n
end program test
The above code fails to compile with the error
ifort tc.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0.2.180 Build 20160204
Copyright (C) 1985-2016 Intel Corporation.  All rights reserved.
tc.f90(17): error #7986: A use associated object that has the PROTECTED attribute shall not appear in a variable definition context.
                n = i
compilation aborted for tc.f90 (code 1)
Is it possible to protect module data and still use the sub-module structure? If I had written this in just a single module there would not have been a problem. Shouldn't a sub-module's procedures have the same access rights to module data as if they were part of the module?
I think this is a compiler bug. A submodule does not "use associate" from its parent (and in fact is not allowed to). I will report it to the developers.
Simon_Geard
Thanks for your prompt response. I'll just have to drop the 'protected' qualification for now.
This bug has been fixed for a future release.
Simon_Geard
Great - thanks. By future do you mean 16.x or 17.x ?
17.0 - it may or may not get fixed in a 16.0 update.
Looks as if it will be fixed in 16.0 Update 3, scheduled for May.
