Purchasing Fortran XE and V11.1
hamid3252
Hi team,
I would like to buy Intel Fortran. My application, which uses Fortan, currently supports V11.1, however the latest version is XE. If I buy XE, can I still download and use V11.1 as well? The reason that I am asking this is that maybe in the future that software starts supporting XE.
Please help clarify my doubt.
Hamidreza,
onkelhotte
New Contributor II
Yes, you can download all previous versions of IVF (starting from IVF 8.0).
Markus
onkelhotte
New Contributor II
Markus
hamid3252
Thank you Markus. May I know where I can download the trial version of IVF 11.1? Following this post (http://redfort-software.intel.com/en-us/forums/showthread.php?t=66453&wapkw=download+fortran+11.1) I need to first provide the serial no. which I don't have. I need to install an evaluation copy of IVF 11.1 first then proceed with the purchase, but all I have access to are Intel Composer XE.
Hamid
First register the serial number you get from requesting the evaluation copy.  Then follow the instructions here to get the older compiler.
