29348 Discussions
Pure procedure inout argument gives error on assignment when using associate construct
Andrew_Smith
Valued Contributor I
This is an extract of the code:
[fortran] pure subroutine calculateAdvancedContactStressContact(aContactPair)
   type(ContactPairType), intent(inout) :: aContactPair
   integer j
   real(8) deltaVec(3)
   deltaVec(1) = 1.0D0
   deltaVec(2:3) = 0.0D0
   associate(aRegion => aContactPair%sides(1)%region)
      do j = 1, size(aRegion%contactRegions)
         associate(def => aRegion%contactRegions(j)%deflection)
            def%vector(1:3)%v = def%vector(1:3)%v - deltaVec
         end associate
      end do
   end associate
end subroutine [/fortran]
<!--break-->
The error message is:
1>Compiling with Intel(R) Visual Fortran Compiler XE 13.0.1.119 [Intel(R) 64]...
1>ContactPair.f90
1>D:\dev\r14.5.1\Components\Source\Romax\StaticAnalysisServer\ContactPair.f90(103): error #7617: This host associated object appears in a 'defining' context in a PURE procedure or in an internal procedure contained in a PURE procedure.   [DEF]
Thanks - I have escalated this as issue DPD200241067. [Edit to correct issue number.]
I expect the fix for this to appear in update 3.
