Q about passing array boundaries or sizes
WSinc
Suppose I have this:
integer x(100)
call xprint(x(23:70) )
end
subroutine xprint(x)
integer x(*)
end subroutine
Normally I would have to ALSO tell it how many elements of X to print.
But I was wondering if there is a subroutine call that would actually tell me how many elements I am passing?
UBOUND and SIZEOF do not work here. I get a compiler error.
If I tell the internal subroutine a fixed number of elements, x(1:20) for example,
then it will use that number, and does not know any thing about the actual size passed to it.
Maybe that is a future enhancement?
DavidWhite
Valued Contributor II
What happens if you use
INTEGER X(:)
in the subroutine?  I believe this behaves differently to the older way you have declared it.
David
IanH
Fortran 90 introduced the concept of assumed shape.  If your subroutine xprint has an explicit interface (perhaps because it is in a module), then you could use an assumed shape declaration (see the colon in the array specification in the following example) for the array argument - and then the compiler will automatically arrange for the shape of the actual argument to be accessible via the dummy argument
SUBROUTINE xprint(x)
  INTEGER :: x(:)
  PRINT "('The size of x is ',I0)", SIZE(x)
END SUBROUTINE xprint
Note that "assumed shape" does not mean "assumed bounds" - for the call in your example the lower bound of the dummy argument x in the above will be 1 (you can specify a different lower bound to use if you want) and the upper bound will be 48.
In your original example you used an assumed size argument, with the * array specifier.  Unlike assumed shape, for an assumed size argument the compiler does not automatically arrange for that size information to be accessible via the dummy argument, hence you can't do operations on that array that implicitly require that size.  The programmer needs to arrange for that size information to be explicitly communicated in some other way.
WSinc
Well, I tried it, but then I get this ERROR 7978
"Interface missing from source file"
error #7978: Required interface for passing assumed shape array is missing from original source
compilation aborted for C:\Users\billsincl\Downloads\test45_0 (1).f90 (code 1)
Why would having it in the MAIN program make any difference?
It works when the CALLING program is in a subroutine.
DavidWhite
You can add an interface to your program as attached.
or put CONTAINS before the subroutine and the END for the program after the end of the subroutine (makes it internal to the program).
IanH
...or put it in a module.
WSinc
Put the SUBROUTINE in a module?
Well, I will try that - but does the compiler REQUIRE that specifically?
DavidWhite
Either you put the subroutine into a module, which is then used by the main program (which then knows the interface for the subroutine), or you explicitly provide the interface information as I did in my example.  Both ultimately provide the main program with the details of the arguments that the subroutine expects, and so eliminates the error that you reported that the interface was missing.
David
WSinc
Can you give me an example of how you did that?
Just stuffing the whole subroutine into a MODULE generated BOUCOUP error messages.
IanH
    module mod001
    CONTAINS   ! <-----
    integer :: x(:)
    nx=size(x)
    print *,"nx=",nx
    end subroutine
    end module
FortranFan
billsincl,
I think I've suggested this to you before, please take the time to study the books recommended by Dr Fortran in his blog at https://software.intel.com/en-us/blogs/2013/12/30/doctor-fortran-in-its-a-modern-fortran-world.  I feel in spite of the best intentions of good, honest folks providing earnest responses to inquiries, the comments in this forum should be viewed more as supplemental material rather than as a primary learning source.  You'd do yourself a great favor if you can take the time to review the material on Fortran 90 onwards in detail.  As you know, you'll then be reminded of the power and flexibility of assumed shape arrays:
MODULE m
   IMPLICIT NONE
   PRIVATE
   PUBLIC :: xprint
CONTAINS
   SUBROUTINE xprint(x, lb)
      !.. Argument list
      INTEGER, INTENT(IN) :: lb
      INTEGER, INTENT(IN) :: x(lb:)
      PRINT *," Size of x: ",        SIZE(x)
      PRINT *," Lower bound of x: ", LBOUND(x)
      PRINT *," Upper bound of x: ", UBOUND(x)
      RETURN
   END SUBROUTINE
END MODULE m
PROGRAM p
    USE m, ONLY : xprint
    IMPLICIT NONE
    INTEGER, PARAMETER :: LL = -10
    INTEGER, PARAMETER :: EXT = 99
    INTEGER :: x(LL:LL+EXT)
    INTEGER :: Id
    Id = 12
    CALL xprint(x(Id:Id+47), Id)
    STOP
END PROGRAM p
  Size of x:           48
  Lower bound of x:           12
  Upper bound of x:           59
WSinc
OH sure, I am aware of the textbooks - -
Its just getting hold of of them, and gleaning out the relevant info thats tricky.
Sometimes they dont give you very direct answers, that why I have to resort to this forum.
I would take a college course if one was available in these parts.
Thanks for your input ! !
Steven_L_Intel1
WSinc
I will certainly study that.
Much more informative than the textbooks I have looked at.
John_Campbell
New Contributor II
Bill,
There are limits to how effective the (:) array syntax is, as the following example shows that the convenience of F90 style array size info is limited only to the size and not the section information.
module info
  contains
    integer x(:)
  end subroutine xprint
end module info
use info
  integer x(100)
end
WSinc
OK, I will try both approaches.
It does not seems obvious to me right offhand which is better.
Thanks for your feedback !
FortranFan
Again, my message can be summed up in 3 words: details, details, details!  I deliberately didn't point our particular details in my example in Quote #11 in order to encourage Bill and others to look them up from better sources such as Dr Fortran blog, books recommended therein, and technical papers, etc.
