29391 Discussions
/Qopenmp and /Qparallel with do concurrent reduce
Fortran10
I see the new version of intel Fortran compiler supports reduction with do concurrent. I wanted to test it with both options of /Qopenmp and /Qparallel with ifort
Do concurrent with reduce
The following code uses do concurrent with reduce.
!  Do concurrent test with reduce
program dc_test
  use omp_lib
  implicit none
  ! variables
  integer ( 4 ), parameter :: x = 256 , y = 256, dx = 1, dy = 1
  integer ( 4 ) :: steps = 100000 , step, i, j, ip, jp, im, jm
  real ( 8 )    :: dt = 0.01 , time_start , time_end, m = 1.0 , k = 0.5
  real ( 8 ), dimension ( :, : ), allocatable :: r, c, f, cc, dc, md
  allocate ( r(x,y) , c(x,y), f(x,y), cc(x,y), dc(x,y), md(x,y) )
  call random_number ( r )
  c = 0.4 + 0.02*( 0.5 - r )
  time_start = omp_get_wtime()
  !--- iteration
  do step = 1, steps
     do concurrent ( integer :: i=1:x, j=1:y )
        f(i,j) =  24.0*c(i,j)*( 1.50 - c(i,j) )**2 - c(i,j)**3*( 1.03 - c(i,j) )
        jp = j + 1
        jm = j - 1
        ip = i + 1
        im = i - 1
        if ( im == 0 ) im = x
        if ( ip == ( x + 1) ) ip = 1
        if ( jm == 0 ) jm = y
        if ( jp == ( y + 1) ) jp = 1
        cc(i,j)   = ( c(ip,j) + c(im,j) + c(i,jm) + c(i,jp) - &
             4.0*c(i,j) ) /( dx*dy )
        dc(i,j) = f(i,j) - k*cc(i,j)
        md(i,j) = ( dc(ip,j) + dc(im,j) + dc(i,jm) &
             + dc(i,jp) - 4.0*dc(i,j) ) / ( dx*dy )
     end do
     ! using reduction
     do concurrent ( integer :: i=1:x, j=1:y ) reduce (+ : c )
        c(i,j) =  c(i,j) + dt*m*md(i,j)
     end do
  end do
  time_end = omp_get_wtime()
  print '("  The time is   = ", f8.3," seconds." )', time_end - time_start
end program dc_test
I performed the tests and got results:
1 ) ifort main.f90 /Qopenmp
stackoverflow error
2 ) ifort main.f90 /Qparallel /QxHost /O3
The code works fine and there is no error!
Do concurrent without reduce
The same code uses do concurrent without reduce.
!  Do concurrent test with no reduce
program dc_test
  use omp_lib
  implicit none
  ! variables
  !--- iteration
  do step = 1, steps
        jp = j + 1
        jm = j - 1
        ip = i + 1
        im = i - 1
     end do
  end do
end program dc_test
3 ) ifort main.f90 /Qopenmp
No error !
4 ) ifort main.f90 /Qparallel /QxHost /O3
No error !
So why does /Qopenmp option shows error when using reduce with do concurrent
jimdempseyatthecove
You may need to link option to set the stack size (larger than default)
Also, with /Qopenmp, the additional OpenMP threads get a default stack size (that may be too small for the reduction). If you must use /Qopenmp, include "use omp_lib" in PROGRAM then at beginnng of the program insert "call kmp_set_stacksize(YourSizeHere)"
Sets to size the number of bytes that will be allocated for each parallel thread to use as its private stack. This value can also be set via the KMP_STACKSIZE environment variable. In order for KMP_SET_STACKSIZE_S() to have an effect, it must be called before the beginning of the first (dynamically executed) parallel region in the program.
or set environment variable OMP_STACKSIZE=sizeYouWant
Jim Dempsey
Barbara_P_Intel
Why are you using /Qparallel? That turns on the auto-parallelizer. I'm not sure what that does if anything with DO CONCURRENT.
As I just posted on another thread the DO CONCURRENT / openmp combination uses OMP SIMD. The parallelization team is looking at using OMP PARALLEL DO in a future release.
What happens if you use ifx?
Fortran10
with ifx the error seems to be the same.
Fortran10
Also after some modifications in the code:
x = 100
y = 100
1)  no reduce
program dc_test
  use omp_lib
  implicit none
  ! variables
  integer ( 4 ), parameter :: x = 100 , y = 100, dx = 1, dy = 1
  real ( 8 )    :: dt = 0.01 , time_start , time_end, time,  m = 1.0 , k = 0.5
  !real ( 8 ), dimension ( x, y ) :: r, c, f, cc, dc, md
 ! call kmp_set_stacksize_s(1000000)
  !--- iteration
  do step = 1, steps
        f(i,j) =  24.0*c(i,j)*( 1.50 - c(i,j) )**2 - &
             &c(i,j)**3*( 1.03 - c(i,j) )
        jp = j + 1
        jm = j - 1
        ip = i + 1
        im = i - 1
     end do
     ! using reduction
     do concurrent ( integer :: i=1:x, j=1:y ) !reduce (+ : c )
     end do
  end do
  time = time_end - time_start
  print*, 'x = ', x
  print*, 'y = ', y
  print*, time
end program dc_test
I get the output.
2) ifx with reduce in do concurrent
No output
jimdempseyatthecove
Jim Dempsey
Barbara_P_Intel
Thanks for the new reproducers! That saved me doing that work. I used the new versions for these tests just now.
I cannot reproduce the runtime failures using ifort with the reduce or without the reduce clause. I used Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.10.0 Build 20230609_000000 on Windows 11 from the Intel(r) oneAPI Tools command windows. Works ok on Linux, too.
Now for ifx, it works just fine without the reduce clause, but with the reduce clause there is no output on Windows as you mentioned. I do get output for both versions on Linux.
I'll get a bug filed against ifx on Windows.
Barbara_P_Intel
I filed CMPLRLLVM-52867. I'll let you know when it's fixed.
Barbara_P_Intel
Compile the reduce version of the reproducer like this and it runs and prints output. As @jimdempseyatthecove pointed out earlier the size of the stack needs to be increased.
Yes, I used ifx. It's the compiler of the future. The -F compiler option also works with ifort.
>ifx -Qopenmp -F20000000 dctest.reduce.f90
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2023.2.0 Build 20230627
Copyright (C) 1985-2023 Intel Corporation. All rights reserved.
Microsoft (R) Incremental Linker Version 14.34.31937.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:dctest.reduce.exe
-subsystem:console
-stack:20000000
-defaultlib:libiomp5md.lib
-nodefaultlib:vcomp.lib
-nodefaultlib:vcompd.lib
dctest.reduce.obj
>dctest.reduce.exe
 x =          100
 y =          100
   8.11413409999977
Fortran10
It does work perfectly fine with ifx. The speed is almost double compared to ifort.
ifort /Qopenmp /F20000000 main.f90
Microsoft (R) Incremental Linker Version 14.32.31332.0
-out:main.exe
-subsystem:console
-stack:20000000
main.obj
>main
 x =          100
 y =          100
   17.5483603999019
ifx /Qopenmp /F20000000 main.f90
-out:main.exe
-subsystem:console
-stack:20000000
main.obj
>main
 x =          100
 y =          100
   9.16886619990692
Fortran10
However using the routine in the code
call kmp_set_stacksize_s(20000000)
with the command
ifx /Qopenmp main.f90
gives no output.
-out:main.exe
-subsystem:console
main.obj
>main
 But with ifort
ifort /Qopenmp main.f90
-out:main.exe
-subsystem:console
main.obj
>main
 x =          100
 y =          100
   17.6567553000059
  I get the output.
Barbara_P_Intel
In anticipation of another question, why is there a performance difference between the version with the reduce and without it?
On my laptop using ifx I see:
reduce   8.11413409999977 seconds
no reduce   3.61359100000027 seconds
Strictly speaking
is not a reduction.
Reduction using addition often would have a form like s = s + x(i), which looks similar to c(i,j) = c(i,j) + dt*m*md(i,j), but the difference is that in s = s + x(i) the same s value is being updated in each loop iteration.
Fortran10
Yeah, I see now that it is not really reduction. Thanks for the clarification. It helps a lot!
Since reduction is a new feature in the latest compiler updates, I was just playing around with it to have a look. Just out of curiosity it was a random shot.
Barbara_P_Intel
The reproducer is doing more work than necessary with both compilers due to the REDUCE clause that isn't really doing a reduce.
Where did you place kmp_set_stack_s()? The DGR states:
"In order for KMP_SET_STACKSIZE_S() to have an effect, it must be called before the beginning of the first (dynamically executed) parallel region in the program."
Fortran10
Yeah, now I put the routine at the top before parallel region.
But the output with Ifx on windows seems to have three different behaviors by using the stack size routine
call kmp_set_stacksize_s( stack_size )
Here is the new modification
program dc_test
  use omp_lib
  implicit none
  ! variables
  integer ( 4 ) :: steps = 1000 , step, i, j, ip, jp, im, jm
  integer ( 8 ) :: stack_size = 20000000
  !=== print array size
  print*, ''
  print*, 'x = ', x
  print*, 'y = ', y
  !--- iteration
  do step = 1, steps
        jp = j + 1
        jm = j - 1
        ip = i + 1
        im = i - 1
     end do
     end do
  end do
  !=== print the computing time here
  print*, 'Time = ', time
end program dc_test
1) When the array is small,
the output (after reduction ) is there i.e. Time
ifx main.f90 /Qopenmp
-out:main.exe
-subsystem:console
main.obj
>main
 x =          100
 y =          100
 Time =   0.101688399910927
2) When the array is big ,
stack overflow error,
no output after reduction,
there is output before reduction
-out:main.exe
-subsystem:console
main.obj
>main
 x =          400
 y =          400
forrtl: severe (170): Program Exception - stack overflow
Image              PC                Routine            Line        Source
main.exe           00007FF7DB711657  Unknown               Unknown  Unknown
main.exe           00007FF7DB6D2DE2  Unknown               Unknown  Unknown
libiomp5md.dll     00007FFA6C71EEC3  Unknown               Unknown  Unknown
libiomp5md.dll     00007FFA6C667BA7  Unknown               Unknown  Unknown
libiomp5md.dll     00007FFA6C668EE9  Unknown               Unknown  Unknown
libiomp5md.dll     00007FFA6C66EC22  Unknown               Unknown  Unknown
libiomp5md.dll     00007FFA6C669686  Unknown               Unknown  Unknown
libiomp5md.dll     00007FFA6C62256C  Unknown               Unknown  Unknown
main.exe           00007FF7DB6D1A86  Unknown               Unknown  Unknown
main.exe           00007FF7DB6D9DDB  Unknown               Unknown  Unknown
main.exe           00007FF7DB711860  Unknown               Unknown  Unknown
KERNEL32.DLL       00007FFAB0A17344  Unknown               Unknown  Unknown
ntdll.dll          00007FFAB1F426B1  Unknown               Unknown  Unknown
3) When the array is in between:
-out:main.exe
-subsystem:console
main.obj
>main
 x =          200
 y =          200
Now for ifort, for the array size between
-out:main.exe
-subsystem:console
main.obj
>main
 x =          200
 y =          200
 Time =    1.58534609992057
  For the small and big array size, the ifort and ifx behaviors are the same.
Barbara_P_Intel
The stack size needs to change with the size of the problem. One size does not fit all.
