Hi there,
my colleague is on a construction site installing one of his programs on the clients machine.
The clients machine has8 Cores. His program is being compiled with the /Qparallel option, but the program uses only 2 Coreswith 100%.
So my question is, does the /Qparallel option "only" optimizes for 2 Cores? Would an OMP approach do better?
I dont know what the clients machine really is (Intel or AMD), but I asked my colleague. Because he cannot go online very often I havent got an answer yet. He usesVisual Studio 2008 9.0.21022.8 RTM andIntel Fortan Compiler 10.1.4159.2008 (seems likethe integration version).
Thanks in advance,
Markus
What version of Windows?
I think thatt he NT -> XP family allowed up to two processors as standard, and you had to move to server editions or pay extrat to access more core. Vista I believe supported four cores as standard, with 'higher' levels of Vista being required to access more cores.
Thanks for that input, I sent my colleague an e-mail, what OS is used there.
I keep you informed.
Markus
The machine uses 2 Xeon E7340 CPUswith 32 GB RAM and Windows 2003 Server SP2 as OS.
Markus
Hi Tim, thanks for the answer.
What do you mean with "controlling environment variable"? Is there some Windows Variable / Definition / Registry entry to set this?
Markus
