I am getting the following warning on linking a static library (which works well with console apps) into a (inprocess) com-dll.
warning LNK4098: defaultlib "libc.lib" conflicts with use of other libs; use /NODEFAULTLIB:library
I have asked this before and the answer has been that the run-time libraries used are not matching.
1. Where can I find these run-time libraries among the project settings?
2. What libraries should I use so that this library is not so darn picky about what type of application is calling it? Or is it not possible?
Thanks in adv.
Tim
Thanks in adv.
Tim
Use
/libdir:noauto
on the static library's project.
/libdir:noauto
