QuickWin Error
Neels
New Contributor II
I suddenly get the following error when compiling and running a QuickWin program:
I have no idea what it means. Please help!
Neels
andrew_4619
Not a lot to go on there.... What are the compiler versions? Have you tried running in debugger? You really need to establish what call in your code lead to the crash and check out the data that is being used on the call as a first line of attack.
Neels
New Contributor II
Andrew,
Thanks for looking at this. More info:
1. Compiler 17.1
2. Win7 64bit
3. Even before it starting in the debugger it gives this error. So I assumed it is in the QWin startup but have really no clue.
Neels
New Contributor II
Many years ago, in the DVF5.0D Steve Lionel answered the question for someone else as:
This error occurs if you try to use the QuickWin libraries from a
Console application.  My guess is that you used Developer Studio to
create a "Win32 Console Application" and then added the QuickWin
libraries.  The correct method is to create a "QuickWin or Standard
Graphics" project (and then you'll get the QuickWin libraries
automatically.)
The software was created in DVF6.0 about 18 years ago. All I can think is something went wrong with the QuickWin part of the project.
andrew_4619
Do a full build and post a build log and that should answer some of the questions on setup.
Neels
New Contributor II
Build log renamed to .txt.
I also found that long-ago answer, but I think this case is different. Monday I'll see if I can identify the particular place in the code that gives this error to see if I can get a hint. If I recall from the distant past, an "internal error" can also result from trying to create a QuickWin window that is "too large". Can you tell us what line of code is being executed when this error occurs?
Neels
New Contributor II
Steve,
The error message appears before the software starts running in the debugger. It also gives this error:
Can you share your project so we can try it ourselves? Use Intel Premier Support if you don't want to attach a ZIP here.
Neels
New Contributor II
I found what causes the error but why it suddenly does so now I do not know. In
Logical(4) FUNCTION INITIALSETTINGS ()
I had this line:
Res    = DISPLAYCURSOR($GCURSORON)
Commenting it out resolved the issue.
DISPLAYCURSOR isn't the sort of thing you should do in INITIALSETTINGS - that's for controlling the appearance of the frame window. DISPLAYCURSOR affects the active window, which there isn't one during INITIALSETTINGS.
Neels
New Contributor II
Steve,
In hindsight it was stupid of me but some sort of error message that gives a clue to a non-programmer would have been helpful.
I'll pass that on to the developers.
