QuickWin on MDI
Manuel
I am trying to develop a program which requires the use of Scigraph library. This library uses the quickwin statements. The issue is I want to create a GUI to control the program and I was thinking in use a MDI project, thus it will require Windows API. The question is if it is possible to merge Scigraph with MDI.
Thanks!
If you want to use Scigraph, it has to be in a QuickWin project. However, you can make Windows API calls from such a project, such as if you want dialogs. You can change the menu through QuickWin calls. You cannot use QuickWin from a "normal" Windows application with its own WinMain entry point.
